Hi Sarah
In the log there're some errors like:
java.lang.IllegalArgumentException: Document base C:\temp\geonetwork242\web\intermap does not exist or is not a readable directory
at org.apache.naming.resources.FileDirContext.setDocBase(FileDirContext.java:142)
Check that you context files are pointing to valid paths. Also which database are you using? Mckoi? In that case you'll need to change with GAST for one the installations the port of Mckoi. There's some messages about Socket bind failed in the log, but not sure if it's a problem of Mckoi.
java.lang.Exception: Socket bind failed: [730048] Normalerweise darf jede Socketadresse (Protokoll, Netzwerkadresse oder Anschluss) nur jeweils einmal verwendet werden.
Also as you comment the port of Z39.50 should be different (probably the above message it's about this)
Jose García
----- Original Message ----- From: <ajs6f@anonymised.com>
To: "geonetwork-users Users" <geonetwork-users@lists.sourceforge.net>
Sent: Monday, November 02, 2009 5:45 PM
Subject: Re: [GeoNetwork-users] two gn instances with one tomcat
Tomcat's stop port is not affected by any application housed in it.
You shouldn't need to change it unless you have a port conflict. I
would change it back. Then we can start to figure out what else is
going wrong.
Which of the various copies of these apps -are- launching?
You will have to change one of the Z39.50 ports to avoid conflict.
A. Soroka
Digital Research and Scholarship R & D
the University of Virginia Library
On Nov 2, 2009, at 11:41 AM, Sarah_S wrote:
I´ve read that this would affect that only one of geonetworks were
stopped
and not both. Ok, so you mean that I have to do this if I use jetty
and not
Tomcat? At my case this port number does not matter.
Think that I have to change Z39.50 port of one of me geonetworks
(like it is
said at manual).
Thanks
best regards
Sarah
ajs6f@anonymised.com wrote:
Why did you change the stop port number on the command line?
A. Soroka
On Nov 2, 2009, at 11:31 AM, Sarah_S wrote:
I´m having geonetwork, geonetwork2, geoserver, geoserver2, intermap
and
intermap2 at my webapps folder.
I don´t want to run jetty. So I was looking at the
HowToRunUnderTomcat but
think that I missed something.
Thanks.
best regards
Sarah
What are the folders that are now in your tomcat/webapps directory?
Are you trying to run both Tomcat and Jetty at the same time?
A. Soroka
On Nov 2, 2009, at 11:22 AM, Sarah_S wrote:
Thanks for the fast answer!
here is my catalina.2009-11-02 log:
WARNUNG: Parameters: Invalid chunk ignored.
02.11.2009 13:26:24 org.apache.catalina.startup.HostConfig
checkResources
INFO: Reloading context [/geonetwork2]
02.11.2009 13:51:28
org.geotools.data.shapefile.indexed.IndexedShapefileDataStore
<init>
SCHWERWIEGEND: null
02.11.2009 13:51:31 org.geotools.factory.FactoryRegistry
scanForPlugins
WARNUNG: Can't load a service for category
"CoordinateOperationFactory".
Cause is "NoClassDefFoundError: javax/vecmath/
SingularMatrixException".
scanForPlugins
02.11.2009 13:51:34 org.geotools.data.shapefile.ShapefileDataStore
createSchema
WARNUNG: PRJ file not generated for null CoordinateReferenceSystem
02.11.2009 13:51:39
<init>
SCHWERWIEGEND: null
02.11.2009 13:51:39 org.geotools.data.shapefile.ShapefileDataStore
createSchema
02.11.2009 13:53:33 org.geotools.factory.FactoryRegistry
scanForPlugins
WARNUNG: Can't load a service for category "ConverterFactory".
Cause
is
"NoClassDefFoundError: org/apache/commons/beanutils/Converter".
02.11.2009 13:54:35 org.apache.catalina.core.StandardContext start
INFO: Container
org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/
geonetwork2]
has already been started
02.11.2009 13:58:03 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error listenerStart
SCHWERWIEGEND: Context [/geoserver2] startup failed due to
previous
errors
02.11.2009 14:05:23
org.wfp.vam.intermap.services.wmc.MailWmcContext
init
WARNUNG: *** The mailserver config property has not been set. WMC
mail will
not be available.
02.11.2009 14:07:39 org.apache.tomcat.util.http.Parameters
processParameters
02.11.2009 14:07:44 org.apache.tomcat.util.http.Parameters
processParameters
02.11.2009 14:08:46 org.apache.tomcat.util.http.Parameters
processParameters
processParameters
02.11.2009 14:11:45 org.apache.tomcat.util.http.Parameters
processParameters
processParameters
02.11.2009 15:30:17 org.apache.catalina.core.AprLifecycleListener
init
INFO: Loaded APR based Apache Tomcat Native library 1.1.16.
init
INFO: APR capabilities: IPv6 [true], sendfile [true], accept
filters
[false], random [true].
02.11.2009 15:30:19 org.apache.coyote.http11.Http11AprProtocol
init
SCHWERWIEGEND: Error initializing endpoint
darf
jede
jeweils einmal
verwendet werden.
at org.apache.tomcat.util.net.AprEndpoint.init(AprEndpoint.java:
623)
at
org.apache.coyote.http11.Http11AprProtocol.init
(Http11AprProtocol.java:107)
at org.apache.catalina.connector.Connector.initialize
(Connector.java:1058)
at
org.apache.catalina.core.StandardService.initialize
(StandardService.java:677)
at
org.apache.catalina.core.StandardServer.initialize
(StandardServer.java:795)
at org.apache.catalina.startup.Catalina.load(Catalina.java:535)
at org.apache.catalina.startup.Catalina.load(Catalina.java:555)
at
(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:260)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:412)
02.11.2009 15:30:19 org.apache.catalina.startup.Catalina load
SCHWERWIEGEND: Catalina.start
LifecycleException: Protocol handler initialization failed:
darf
jede
jeweils einmal
verwendet werden.
(Connector.java:1060)
at
at
at
at
INFO: Initialization processed in 2448 ms
02.11.2009 15:30:20 org.apache.catalina.core.StandardService start
INFO: Starting service Catalina
02.11.2009 15:30:20 org.apache.catalina.core.StandardEngine start
INFO: Starting Servlet Engine: Apache Tomcat/6.0.20
02.11.2009 15:30:20 org.apache.catalina.core.StandardContext
resourcesStart
SCHWERWIEGEND: Error starting static Resources
C:\temp\geonetwork242\web\geonetwork does not exist or is not a
readable
directory
at
at
org.apache.catalina.core.StandardContext.resourcesStart
(StandardContext.java:4048)
at
org.apache.catalina.core.StandardContext.start
4217)
at org.apache.catalina.core.ContainerBase.start
(ContainerBase.java:
1045)
at org.apache.catalina.core.StandardHost.start(StandardHost.java:
722)
1045)
at org.apache.catalina.core.StandardEngine.start
(StandardEngine.java:443)
at org.apache.catalina.core.StandardService.start
(StandardService.java:516)
at org.apache.catalina.core.StandardServer.start
(StandardServer.java:710)
at org.apache.catalina.startup.Catalina.start(Catalina.java:583)
at
at
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:
288)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:413)
02.11.2009 15:30:20 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error in resourceStart()
02.11.2009 15:30:21 org.apache.catalina.core.StandardContext start
SCHWERWIEGEND: Error getConfigured
SCHWERWIEGEND: Context [/geonetwork2] startup failed due to
previous
errors
02.11.2009 15:30:21 org.apache.catalina.core.StandardContext stop
INFO: Container
geonetwork2]
has not been started
02.11.2009 15:34:01 org.apache.catalina.core.StandardContext
resourcesStart
C:\temp\geonetwork242\web\geoserver does not exist or is not a
readable
directory
at
at
at
4217)
1045)
722)
1045)
at
at
288)
02.11.2009 15:34:01 org.apache.catalina.core.StandardContext start
previous
errors
02.11.2009 15:34:01 org.apache.catalina.core.StandardContext stop
INFO: Container
geoserver2]
resourcesStart
readable
directory
at
at
at
4217)
1045)
722)
1045)
at
at
288)
SCHWERWIEGEND: Context [/intermap2] startup failed due to previous
errors
INFO: Container
intermap2]
02.11.2009 15:34:20
init
mail will
not be available.
02.11.2009 15:34:22 org.apache.catalina.startup.HostConfig
deployWAR
INFO: Deploying web application archive servlet.war
deployWAR
INFO: Deploying web application archive wfsconnector.war
deployWAR
INFO: Deploying web application archive wmsconnector.war
02.11.2009 15:34:23 org.apache.coyote.http11.Http11AprProtocol
start
SCHWERWIEGEND: Error starting endpoint
darf
jede
jeweils einmal
verwendet werden.
623)
at org.apache.tomcat.util.net.AprEndpoint.start(AprEndpoint.java:
730)
at
org.apache.coyote.http11.Http11AprProtocol.start
(Http11AprProtocol.java:137)
at org.apache.catalina.connector.Connector.start(Connector.java:
1131)
(StandardService.java:531)
at
at
288)
02.11.2009 15:34:23 org.apache.catalina.startup.Catalina start
SCHWERWIEGEND: Catalina.start:
LifecycleException: service.getName(): "Catalina"; Protocol
handler start
failed: java.lang.Exception: Socket bind failed: [730048]
Normalerweise darf
jeweils
1138)
at
at
288)
INFO: Server startup in 243136 ms
02.11.2009 15:34:23 org.apache.catalina.core.StandardServer await
SCHWERWIEGEND: StandardServer.await: create[8005]:
java.net.BindException: Address already in use: JVM_Bind
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:365)
at java.net.ServerSocket.bind(ServerSocket.java:319)
at java.net.ServerSocket.<init>(ServerSocket.java:185)
at org.apache.catalina.core.StandardServer.await
(StandardServer.java:373)
at org.apache.catalina.startup.Catalina.await(Catalina.java:647)
at org.apache.catalina.startup.Catalina.start(Catalina.java:607)
at
at
288)
I have to make some changes at some files- but don´t exactly know
which one.
Thanks
best regards
Sarah
What errors appear in logs/catalina.out?
A. Soroka
On Nov 2, 2009, at 11:08 AM, Sarah_S wrote:
I want to run two geonetworks (2.4.1 and 2.4.2) top of my
tomcat.
2.4.1 was
put up. So I copied the three web folders (geonetwork,
geoserver,
intermap -
renamed to geonetwork2,..) to webapps folder of tomcat and
modified
server.xml. At start-geonetwork.sh I changed --DSTOP.PORT to
8078.
At tomcat manager I see that geonetwork2, geoserver2 amd
intermap2
weren´t
started and could not be started.
What did I miss?
Thanks.
best regards
Sarah
View this message in context:
http://n2.nabble.com/two-gn-instances-with-one-tomcat-tp3932679p3932679.html
Sent from the GeoNetwork users mailing list archive at Nabble.com
Come build with us! The BlackBerry(R) Developer Conference in
SF, CA
is the only developer event you need to attend this year.
Jumpstart
your
developing skills, take BlackBerry mobile applications to market
and
stay
ahead of the curve. Join us from November 9 - 12, 2009. Register
now!
http://p.sf.net/sfu/devconference
GeoNetwork-users mailing list
Come build with us! The BlackBerry(R) Developer Conference in SF,
CA
Jumpstart
your
and stay
now!
http://n2.nabble.com/two-gn-instances-with-one-tomcat-tp3932679p3932768.html
SF, CA
Jumpstart
your
and
stay
now!
CA
is the only developer event you need to attend this year. Jumpstart
your
and stay
now!
http://n2.nabble.com/two-gn-instances-with-one-tomcat-tp3932679p3932837.html
Come build with us! The BlackBerry(R) Developer Conference in SF, CA
your
developing skills, take BlackBerry mobile applications to market and
stay
now!
your
and stay
ahead of the curve. Join us from November 9 - 12, 2009. Register now!
View this message in context: http://n2.nabble.com/two-gn-instances-with-one-tomcat-tp3932679p3932919.html
your
stay
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
