I did a search of the archives and can not find any reference to this
problem.
I installed according to the 2.1 tutorial
(http://geonetwork-opensource.org/documentation/how-to/installing-geonetwork-2-1-0-on-ubuntu)
which seemed the most appropriate option. I go to
http://localhost/geonetwork
and I'm getting the following error:
Not Found
The requested URL /geonetwork/srv/en/main.home was not found on this
server.
Apache/2.2.11 (Ubuntu) mod_jk/1.2.26 PHP/5.2.6-3ubuntu4.5 with
Suhosin-Patch Server at localhost Port 80
I've double checked my config files to match the tutorial as well as
permissions, and restarted apache but the error persists.
Any insight into possible causes for this problem would be greatly
appreciated.
TSW
hi Trevor,
from what you write, I'd say it's most likely you use the default port of
Tomcat, which is 8080. So try http://localhost:8080/geonetwork ?
Kind regards
Heikki Doeleman
On Wed, Jan 27, 2010 at 12:30 AM, Trevor Wiens <twiens@anonymised.com> wrote:
problem.
Not Found
server.
appreciated.
TSW
The Planet: dedicated and managed hosting, cloud storage, colocation
Stay online with enterprise data centers and the best network in the
business
Choose flexible plans and management services without long-term contracts
Personal 24x7 support from experience hosting pros just a phone call away.
http://p.sf.net/sfu/theplanet-com
GeoNetwork-users mailing list
right,
sorry, I now see you want to set it up through Apache, in which case you
wouldn't need port 8080 ..
So I'll pass this on.
Success !
Heikki Doeleman
On Wed, Jan 27, 2010 at 1:43 AM, heikki <tropicano@anonymised.com> wrote:
hi Trevor,
Kind regards
Heikki Doeleman
problem.
Not Found
server.
appreciated.
TSW
business
I also receive this error when going to localhost/geonetwork and have not
been able to solve it. Do you know if anyone has found a solution yet?
server.
View this message in context: http://n2.nabble.com/Ubuntu-9-04-Tomcat-5-5-Geonetwork-2-4-2-404-geonetwork-srv-en-main-home-was-not-found-on-this-server-tp4464249p4595672.html
firstly, Do you have access to localhost:8080/geonetwork
(8080--> default tomcat port; chabge if it is not yours.)
Marc-André
View this message in context: http://n2.nabble.com/Ubuntu-9-04-Tomcat-5-5-Geonetwork-2-4-2-404-geonetwork-srv-en-main-home-was-not-found-on-this-server-tp4464249p4612290.html
