[GeoNetwork-users] Unable to load the metadata even if it exists into the database
Dear list,
I'm over geonetwork 3.8.x and I'm trying to figure out how a metadata
existing into the database is not showing into the UI... (I see it's uuid
into the table and the iso metadata)
The metadata looks correct and I've several of them with the same problem.
Running manually the following (as Administrator):
http://XXXXX/geonetwork/api/0.1/records/index?uuids=1413ce80XXXXXXXXX-000d939bc5d8
I was expecting to reindex the metadata into Lucene having something
different than:
{"success":true,"count":0}
Nothing comes out from the log.
Do you have an Idea or any experience about that?
What's happening?
Is there something else that I can do to 'load' this metadata from the
database?
Best regards,
C.
Mr. Carlo Cancellieri
Hi Carlo
Please if you can create an issue in GitHub and attach the metadata record.
Jose García
On Thu, Mar 11, 2021 at 4:18 PM carlo cancellieri <
geo.ccancellieri@anonymised.com> wrote:
Dear list,
different than:
What's happening?
database?
Best regards,
C.
GeoNetwork-users mailing list
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
Thanks, I’ll check with the metadata owner if I’m able to share.
My best,
C
Il giorno lun 15 mar 2021 alle 14:15 Jose Garcia <jose.garcia@anonymised.com>
ha scritto:
Hi Carlo
Jose García
Dear list,
different than:
What's happening?
database?
Best regards,
C.
<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt;6721
WD Bennekom
<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt;The
Netherlands
<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt;T: +31
this email.*
*skype*: ccancellieri
*Twitter*: @cancellieric
*LinkedIn*: http://it.linkedin.com/in/ccancellieri/
Hi Carlo,
I have a few more questions that will help reduce the number of possible causes:
Does the record display in Full view? If the record is in the database and displays in full view but not the default view, that suggests the record has not been indexed successfully. I believe the default view does not access the database but gets its information from the index.
If the record was not created using the same GeoNetwork installation, I suggest:
  1. Check that the medataStandardName in the ISO record is correct and the namespace declarations in the record are correct. These could be causes of the record not displaying because it could not be determined which standard it is using. (schema-ident transforms)
  2. We had some unexpected values in the metadata database table in the column that has the root element. I do not remember the exact details, but a few records had gmd:MD_Metadata instead of MD_Metadata (or the opposite). The ones that were wrong did not display even though they were in the database.
Which ISO version is used for the records (19139, 19115-3(2014), 19115-3(2018)?
We have both 19115-3 versions included in our deployment to better handle import of records that do not clearly identify which revision year they used. This seems to be an easy copy/paste error if some manually creates a new record from a previous one. We also had an apparent bug in the XML transform between the two year revisions that failed to change the metadataStandardName to the output name.
Could there be a problem with the metadata profile (INSPIRE etc) used by the records that do not display properly.
I hope this is helpful in identifying the source of the problem.
Jeff
My best,
C
Il giorno lun 15 mar 2021 alle 14:15 Jose Garcia [<jose.garcia@anonymised.com>](mailto:jose.garcia@anonymised.com)
ha scritto:
Hi Carlo
Jose García
[geo.ccancellieri@anonymised.com](mailto:geo.ccancellieri@anonymised.com)> wrote:
Dear list,
[http://XXXXX/geonetwork/api/0.1/records/index?uuids=1413ce80XXXXXXXXX-000d939bc5d8](http://XXXXX/geonetwork/api/0.1/records/index?uuids=1413ce80XXXXXXXXX-000d939bc5d8)
different than:
What's happening?
database?
Best regards,
C.
[GeoNetwork-users@lists.sourceforge.net](mailto:GeoNetwork-users@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geonetwork-users](https://lists.sourceforge.net/lists/listinfo/geonetwork-users)
[http://sourceforge.net/projects/geonetwork](http://sourceforge.net/projects/geonetwork)
[<http://www.geocat.net/>](http://www.geocat.net/)Veenderweg 13
[<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g>](https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g)6721
WD Bennekom
[<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g>](https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g)The
Netherlands
[<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g>](https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g)T: +31
this email.*
Thanks Jeff,
your answer is very helpful.
The namespaces were wrong for some reason. I'll go in deep also looking to
roots etc.
Very appreciated.
Best,
C.
Il giorno mar 16 mar 2021 alle ore 00:10 Jeff Campbell <
dev@anonymised.com> ha scritto:
Hi Carlo,
causes:
suggest:
   database.
19115-3(2018)?
Jeff
My best,
C
Il giorno lun 15 mar 2021 alle 14:15 Jose Garcia <jose.garcia@anonymised.com> <jose.garcia@anonymised.com>
ha scritto:
Hi Carlo
Jose García
On Thu, Mar 11, 2021 at 4:18 PM carlo cancellieri <geo.ccancellieri@anonymised.com...> wrote:
Dear list,
different than:
What's happening?
database?
Best regards,
C.
GeoNetwork-users mailing listGeoNetwork-users@anonymised.com://lists.sourceforge.net/lists/listinfo/geonetwork-users
GeoNetwork OpenSource is maintained athttp://sourceforge.net/projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García<http://www.geocat.net/&gt; <http://www.geocat.net/&gt;Veenderweg 13<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt; <https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt;6721
WD Bennekom<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt; <https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt;The
Netherlands<https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt; <https://www.google.com/maps/search/Veenderweg+13+6721+WD+Bennekom+The+Netherlands?entry=gmail&source=g&gt;T: +31
this email.*
