[GeoNetwork-users] Unable to search metadata record
Hi there,
I've created a metadata record (ISO19139), set privileges to 'All' and I'm
unable to display in the search results. It's just one record, others I've
tried are okay?
Tried rebuilding lucene index, but still it is not searchable. However, the
record is displayed in the GeoRSS feed and the metadata is displayed by
clicking on the latter link, and I can find it by pasting its unique ID into
the browser.
An issue with the search/indexing function?
Richard
(GN v2.6.3)
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-search-metadata-record-tp5962306p5962306.html
hi Richard,
hard to say. The fact that you can open the metadata from the link in RSS or
by pasting its URL in the browser indicates that setting the privileges to
"All" as such works (assuming you're not logged in when doing that).
You say it's just one record has this, others you created are fine ? Can you
think of *any* difference in how you created the record that does not show
up in search, and the other ones ?
An option could be to examine the data for this record in the database, and
to examine the entry in the Lucene index for it. This latter you could do
using a Lucene-index-browser called Luke.
Did you try what happens if you save the metadata (in XML) and try to insert
that again (check the option to generate new UUID) ? If you can reproduce
the non-findability of this metadata, while you can do the same with others
and find them, could you post that metadata ?
Kind regards
Heikki Doeleman
On Wed, Jan 26, 2011 at 12:03 PM, RichC <richard@anonymised.com> wrote:
Hi there,
tried are okay?
into
the browser.
Richard
(GN v2.6.3)
Special Offer-- Download ArcSight Logger for FREE (a $49 USD value)!
Finally, a world-class log management solution at an even better
price-free!
Download using promo code Free_Logger_4_Dev2Dev. Offer expires
February 28th, so secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsight-sfd2d
GeoNetwork-users mailing list
insert that again (check the option to generate new UUID) ?
Inserted the record with a new ID and this new record is similarly not
discoverable in the search.
you think of *any* difference in how you created the record that does not
show up in search, and the other ones ?
The missing record is quite a comprehensive and detailed record, while the
records I can search were 'test' records created by changing the title only.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-search-metadata-record-tp5962306p5962531.html
It appears that a single entry in the Equivalent Scale/Denominator field was
the cause. I had previously entered 'various scales' which appears to cause
the problem. It was showing up in red so I guessed something might be awry.
Anyway, on removing 'various scales' and re-saving the record became
searchable.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-search-metadata-record-tp5962306p5962726.html
Hi Richard:
Did you try to restart the servlet?
We got the same problem and the "solution" we found was that.
Regards.
Miguel.
Miguel Ángel Parrilla Godínez
Dpto. de Sistemas de Información Territorial
Técnico de la sección de sistemas corporativos
948289080 Ext 279
maparrilla@anonymised.com
C/ Cabárceno, 6. 31621. Sarriguren. Navarra. España.
[T. 948 289 000 | F. 948 249 209]
[www.tracasa.es]
-----Mensaje original-----
De: RichC [mailto:richard@anonymised.com]
Enviado el: miércoles, 26 de enero de 2011 13:33
Para: geonetwork-users@lists.sourceforge.net
Asunto: Re: [GeoNetwork-users] Unable to search metadata record
AVISO SOBRE CONFIDENCIALIDAD: La información incluida en este mensaje es CONFIDENCIAL y de uso EXCLUSIVO a su FINALIDAD. Su posterior divulgación será responsabilidad de quien la realice
Hi Miguel,
I think that I did try by restarting GN but it didn't solve the problem in
my case.
Richard
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Unable-to-search-metadata-record-tp5962306p5987979.html
