[GeoNetwork-users] Unable to upload a file in Online resource section
Dear reader
I have set up geonetwork+tomcat+postgres
everything works fine - I have created a series of metadata
However, I face a problem when trying to upload a file under
Online Resource section. In fact only the Web address (URL)
option works there.
So when attempting to upload the file I get the following message:
"The requested operation could not be performed. "
I found the following lines under
C:\Program Files\Apache Software Foundation\Tomcat 5.5\log\jeeves
2008-03-04 23:05:41,050 ERROR [jeeves.service] - Exception when executing service
2008-03-04 23:05:41,051 ERROR [jeeves.service] - (C) Exc : java.lang.Exception: unable to move uploaded file to destination directory
2008-03-04 23:05:41,054 DEBUG [jeeves.service] - Raised exception while executing service
<error id="error">
  <message>unable to move uploaded file to destination directory</message>
  <class>Exception</class>
  <stack>
    <at class="org.fao.geonet.services.resources.Upload" file="Upload.java" line="87" method="exec" />
    <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="238" method="execService" />
    <at class="jeeves.server.dispatchers.ServiceInfo" file="ServiceInfo.java" line="141" method="execServices" />
    <at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="372" method="dispatch" />
    <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="600" method="dispatch" />
    <at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="163" method="execute" />
    <at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="98" method="doPost" />
    <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="709" method="service" />
    <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="802" method="service" />
    <at class="org.apache.catalina.core.ApplicationFilterChain" file="ApplicationFilterChain.java" line="252" method="internalDoFilter" />
  </stack>
  <request>
    <language>en</language>
    <service>resources.upload</service>
  </request>
</error>
Any help/suggestion whould be greatly appreciated
Thanking you in advance
Emmanuel.
Hello Emmanuel,
Have a look to the authorisations on the Data directory.
Geonetwork/.../web/geonetwork/WEB-INF/data
Tomcat must be authorized to read (and write ) this directory and
subdirectories to copy the files uploaded.
That is my suggestion :wink:
Best Regards,
Fabien Bachraty
E.Stefanakis-2 wrote:
Dear reader
option works there.
service
executing service
<error id="error">
  <stack>
  </stack>
  <request>
  </request>
</error>
Emmanuel.
Defy all challenges. Microsoft(R) Visual Studio 2008.
GeoNetwork-users mailing list
View this message in context: http://www.nabble.com/Unable-to-upload-a-file-in-Online-resource-section-tp15837490s18419p15844447.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Dear Fabien
In this directory I can find the thumbnails - so it seems there is
authorized access...
Thanks!
Emmanuel.
----- Original Message ----- From: "FBachraty" <Fabien.Bachraty@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Wednesday, March 05, 2008 9:09 AM
Subject: Re: [GeoNetwork-users] Unable to upload a file in Online resource section
Hello Emmanuel,
Best Regards,
Fabien Bachraty
Dear reader
option works there.
service
executing service
<error id="error">
  <stack>
  </stack>
  <request>
  </request>
</error>
Emmanuel.
Maybe you are true.
But Tomcat create a user to work and acces your disk.
This user must have the read and write authorisation not your user;)
The user is named Tomcat5 maybe Tomcat55 for the realease 5.5
I am not sure have a look :slight_smile:
Have can also look to the tomcat policy file.
Try to add something like this
grant codeBase "file:/usr/local/Geonetwork/-"
        permission java.security.AllPermission;
Either have a look to this interesting post :
http://www.nabble.com/File-upload-error-to13102530s18419.html#a13102530
edit the metadata-edit.xsl
and add this attribute to the form:
enctype="multipart/form-data"
best regards
Fabien Bachraty
Dear Fabien
Thanks!
Emmanuel.
View this message in context: http://www.nabble.com/Unable-to-upload-a-file-in-Online-resource-section-tp15837490s18419p15845459.html
Could you please guide me where to put this
Thanks!
Emmanuel.
Sent: Wednesday, March 05, 2008 10:40 AM
Maybe you are true.
best regards
Fabien Bachraty
Dear Fabien
Thanks!
Emmanuel.
Hi Emmanuel,
Unless you have an old version, this fix is already part of version 2.2RC0 and RC1 (search the metadata-edit.xsl file for that string to be sure). Otherwise it should be added in the JavaScript function doFileUploadAction as:
        document.mainForm.action = action;
        document.mainForm.enctype="multipart/form-data";
        goSubmit('mainForm');
(Only the middle line obviously).
If it doesn't work with the line added, please try Fabien's solution and let us know if that worked!
Ciao,
Jeroen
Thanks!
Emmanuel.
section
Maybe you are true.
best regards
Fabien Bachraty
Dear Fabien
Thanks!
Emmanuel.
geonetwork-users List Signup and Options
GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Dear Jeroen
I've version 2.1
the metadata-edit.xsl file is slightly different...
here is the doFileUploadAction:
   function doFileUploadAction(action, ref, fname, access)
    // alert("In doFileUploadAction(" + action + ", " + ref + ", " + fname + ")"); // DEBUG
    if (fname.indexOf('/') > -1)
     fname = fname.substring(fname.lastIndexOf('/') + 1, fname.length);
    else
     fname = fname.substring(fname.lastIndexOf('\\') + 1, fname.length);
    document.mainForm.fname.value = fname;
    document.mainForm.access.value = access;
    doElementAction(action, ref);
I will try version 2.2... and let you know.
Thanks again!
Emmanuel
----- Original Message ----- From: "Jeroen Ticheler" <Jeroen.Ticheler@anonymised.com>
To: "E.Stefanakis" <estef@anonymised.com>
Cc: "FBachraty" <Fabien.Bachraty@anonymised.com>; <geonetwork-users@lists.sourceforge.net>
Sent: Wednesday, March 05, 2008 11:30 AM
Subject: Re: [SPAM] Re: [GeoNetwork-users] Unable to upload a file in Online resource section
Hi Emmanuel,
Ciao,
Jeroen
Thanks!
Emmanuel.
section
Maybe you are true.
best regards
Fabien Bachraty
Dear Fabien
Thanks!
Emmanuel.
Dear all
I have tried all these alternatives without success...
... still get the same message.
Emmanuel.
Hi Emmanuel,
Ciao,
Jeroen
Thanks!
Emmanuel.
section
Maybe you are true.
best regards
Fabien Bachraty
Dear Fabien
Thanks!
Emmanuel.
