I have some trouble with my new GeoNetwork installation. I installed the new GN2.2 version und set up a new database. After that I integrated the contend of the old database into the new via sql.
What is the exception appearing in the logs of your servlet container (Tomcat or Jetty or other)?
A. Soroka / Digital Scholarship Services R & D
the University of Virginia Library
On Jan 13, 2009, at 3:44 AM, Christian Gadge wrote:
Hello,
Hi Christian,
Did you ensure the System preferences (in the Admin panel) are correct? Are yo indeed testing on localhost, or is the server running on another URL?
If you run on localhost, try to use 127.0.0.1 instead of the name localhost, I remember having problems using localhost on Safari in the past.
Ciao,
Jeroen
On Jan 13, 2009, at 9:44 AM, Christian Gadge wrote:
Hello,
it seems that the system preferences settings are the reason for this error. First I set the host to localhost / 127.0.0.1 and uploaded data. This works fine.
Later I changed the settings to host 'anotherURL'. Now the download of new uploaded data is possible. Only data which was uploaded with host 127.0.0.1 download is not possible. This url stored in metadata does not work, isn't it?
Christian
----- Ursprüngliche Nachricht -----
Von: Jeroen Ticheler <Jeroen.Ticheler@anonymised.com>
Datum: Dienstag, 13. Januar 2009, 23:18
Betreff: Re: [GeoNetwork-users] unable to upload data
An: Christian Gadge <christian.gadge@anonymised.com>
Cc: geonetwork-users <geonetwork-users@lists.sourceforge.net>
Hi Christian,
are
running
on another URL?
name
in the
past.
Ciao,
Jeroen
> Hello,
installed
I
> Now when I want to download data which was uploaded with the
new
> GeoNetwork installation an error appears:
(http://localhost:8080/geonetwork/srv/en/resources.get?id=336&fname=nameofmydataset.pdf&access=private
> ) cannot connect to server under localhost:8080.
> But I could upload the file...
> Downloading data that was uploaded with an old GN installation
(and
> integrated into the new database) works fine.
> Greetings,
> Christian
> This SF.net email is sponsored by:
> SourcForge Community
> SourceForge wants to tell your story.
> http://p.sf.net/sfu/sf-spreadtheword
> GeoNetwork-users mailing list
> GeoNetwork-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geonetwork-users
> GeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork>
