[GeoNetwork-users] Unix Headless Install?
Solved this one. Used the windows installer to create an
auto-install.xml, then hacked it for the Unix machine.
Don't know why I couldn't persuade the -console switch to behave :frowning:
Justin.
Sent: 02 August 2010 11:37
To: 'geonetwork-users@lists.sourceforge.net'
Subject: Unix Headless Install?
Does anyone know if it is possible to use the installer on a shell-only
Unix? Are there any switches I can use to install without X?
Justin.
This email is only intended for the person to whom it is addressed and may contain confidential information. If you have received this email in error, please notify the sender and delete this email which must not be copied, distributed or disclosed to any other person.
Unless stated otherwise, the contents of this email are personal to the writer and do not represent the official view of Ordnance Survey. Nor can any contract be formed on Ordnance Survey's behalf via email. We reserve the right to monitor emails and attachments without prior notice.
Thank you for your cooperation.
Ordnance Survey
Romsey Road
Southampton SO16 4GU
Tel: 08456 050505
http://www.ordnancesurvey.co.uk
