[GeoNetwork-users] Update GN 2.0 to 2.2
Hello everybody,
I would have a feedback about the update from the Geonetwork 2.0 to the
GeoNetwork 2.2.
How do we have to do ?
We must install the new version 2.2 ?
Do we lose the metadata of the previous version (2.0)?
Thank you for your help
Arno
View this message in context: http://www.nabble.com/Update-GN-2.0-to-2.2-tp16953728s18419p16953728.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
Hi Arno,
You have to install the new version next to the old one. Configure the new instance to suit your needs and use GAST for the migration. At the end of that migration you may also want to convert ISO19115 formatted metadata into ISO19139 formatted metadata, again using GAST.
There are some instructions in the respective panels in GAST.
Ciao,
Jeroen
On Apr 29, 2008, at 9:40 AM, arnod wrote:
Hello everybody,
GeoNetwork 2.2.
Arno
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Don't miss this year's exciting event. There's still time to save $100.
Use priority code J8TL2D2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/javaone
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at GeoNetwork - Geographic Metadata Catalog download | SourceForge.net
Ok
Thank you very much Jeroen,
I have a question about this "new version next to the old one"...
I don't understand "next". Is it "instead of the old one" ?
Can you explain please?
This new version keeps the metadata of the old version without changes ?
Thanks
Arno
----- Mail Original -----
De: "Jeroen Ticheler" <Jeroen.Ticheler@anonymised.com>
À: "arnod" <deleurmea@anonymised.com>
Cc: geonetwork-users@lists.sourceforge.net
Envoyé: Mardi 29 Avril 2008 10:15:58 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne
Objet: Re: [GeoNetwork-users] Update GN 2.0 to 2.2
Hi Arno,
Ciao,
Jeroen
Hello everybody,
the
GeoNetwork 2.2.
Arno
$100.
Hi Arno,
On Apr 29, 2008, at 11:40 AM, Arnaud DELEURME wrote:
Ok
You install the new version in a new location, e.g. in c:\geonetwork220 or so. The migration will transfer all metadata, privileges and data to the new database and new data location (if you want to keep the data in the same location, first configure the data location of the gn2.2 version to point to the same data directory as the GN2.0 version. this is done in the config.xml file in the web/geonetwork/WEB-INF folder, around line 122 (<param name="dataDir" value="WEB-INF/data" />)).
The migration will ingest the metadata from the old installation but will not by default transform the metadata into 19139 formatted records. That's what requires the second action I described.
Hope this helps.
Ciao,
Jeroen
Thanks
Arno
De: "Jeroen Ticheler" <Jeroen.Ticheler@...5...>
À: "arnod" <deleurmea@...298...>
Hi Arno,
Ciao,
Jeroen
> Hello everybody,
> the
> GeoNetwork 2.2.
> Arno
> $100.
   Hello,
   Is there any possibility to get user/group specific content on the first page of GeoNetwork?
   Regards, David.
geoinformation+planung
reichert+partner ingenieure
gölzstr. 22 72072 tübingen
fon: +49 (0)7071-407360
fax: +49 (0)7071-407361
info@anonymised.com
http://www.geoinformation-planung.de
Regionalplan Schwarzwald-Baar-Heuberg online: http://www.regionalplan-sbh.de
Hi David,
Could you explain that a little more? How should it appear for instance? Instead of something available already?
Ciao,
Jeroen
On Apr 30, 2008, at 8:30 AM, David Arndt wrote:
  Hello,
  Regards, David.
info@...306...
On 4/30/08, David Arndt <arndt@anonymised.com> wrote:
   Hello,
Very, very raw right now, but see http://speedy.ersc.wisc.edu:8080/geonetwork/
In a week's time it will look completely different.
   Regards, David.
info@anonymised.com
Puneet Kishor http://punkish.eidesis.org/
Nelson Institute for Environmental Studies http://www.nelson.wisc.edu/
Open Source Geospatial Foundation (OSGeo) http://www.osgeo.org/
