Would you tell me how I can update privileges against entire records ?
I'd like to allow every record Guest/Publish access.
And how do I give Guest/Publish privilege at batch import ?
All I can choose is "Sample Group" at the pulldown.
Thanks for your help.
Yoshi
Yoshi,
I suggest that you look at the MEF file format. It is simply a structured
zip file. In there, you can specify all the metadata records that you want
to load as well as the permissions, categories, public/private data, etc....
Then you can upload the MEF file via the web interface.
View this message in context: http://osgeo-org.1560.n6.nabble.com/update-privileges-against-entire-records-tp4998537p4998558.html
