[GeoNetwork-users] upgrade 2.2 -> 2.4
we have two Geonetwork 2.2 instances running on CentOS+Tomacat6. Now I would like to upgrade to 2.4. Is it enough to just replace all version 2.2 WAR files with the 2.4 files? Or did the database structure change and i need to make a schema upgrade first?
Thanks for your help
Frank
Hi Frank,
Did you get any response for this? I’m in a similar position.
Many thanks,
Andy
I've found that there are some database changes, particularly in the settings table. Not schema changes, but a fair number of new settings have been added that will mess you up if you don't have them.
Roger
Sent: Tuesday, August 04, 2009 10:51 AM
To: Frank
Cc: Geonetwork Users
Subject: Re: [GeoNetwork-users] upgrade 2.2 -> 2.4
Hi Frank,
Did you get any response for this? I'm in a similar position.
Many thanks,
Andy
Frank wrote:
Frank
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day
trial. Simplify your report design, integration and deployment - and focus on
what you do best, core application coding. Discover what's new with
Crystal Reports now. http://p.sf.net/sfu/bobj-july
GeoNetwork-users mailing list
