I need to make use of reprojection in the Map viewer in geonetwork, now it
seems OpenLayers has supported this for a couple of years now but it seems
not to be present in the GN version. So I'm trying to upgrade the ngeo libs
<https://github.com/camptocamp/ngeo>which would be cool if master built,
but anyway I got 2.1.x to build and thought I could just drop that into the
the GN directory structure but no, it fails with a missing angular
dependency on ui.date (or possibly something else entirely). So then I
rebuilt the GN war incase there was some magic baked in during packaging
but no it still fails.
So does anyone know how to update the version of openlayers in a GN
install? It doesn't even have to be a very recent one, latish 3.x would do
Ian
Ian Turton
Actually the ngeo build cannot provide a correct dist build version, it
won't work.
We are stuck about this for the moment, i'm planning to discuss about that
at the code sprint next week.
I think what i could do for now is to provide a more recent version of ngeo
that contains the reprojection, but it won't be the last one as it has not
been buildable for geonetwork for at least 6 months.
What you can try:
put your ngeo branch at a commit from one year ago.
in the package.json, make sure to use the version of ol3 that was released
at the same date, and build ngeo.js and ngeo-debug.js ...
Ian
Ian Turton
Check out the vibrant tech community on one of the world's most
GeoNetwork-users mailing list
geonetwork-users List Signup and Options
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
*Florent Gravin*
0479444492
Also ...
if you have activated the 3D viewwith Cesium, then the ol version is more
recent and has the client reprojection.
On Wed, Jun 7, 2017 at 3:56 PM, Florent Gravin <
florent.gravin@anonymised.com> wrote:
won't work.
ngeo that contains the reprojection, but it won't be the last one as it has
not been buildable for geonetwork for at least 6 months.
What you can try:
libs
the
Ian
Ian Turton
GeoNetwork OpenSource is maintained at Best Open Source Mac Software 2024
s/geonetwork
*camptocamp*
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
On 14 June 2017 at 15:07, Florent Gravin <florent.gravin@anonymised.com>
wrote:
Also ...
Is that just in the 3D viewer or in general?
Also did upgrading OL make it to the sprint list of tasks this week?
Ian
won't work.
that at the code sprint next week.
What you can try:
released at the same date, and build ngeo.js and ngeo-debug.js ...
it
seems
libs
the
do
Ian
Ian Turton
GeoNetwork OpenSource is maintained at http://sourceforge.net/project
s/geonetwork
*camptocamp*
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
Ian Turton
If 3D is activated, then the js file is ol3 + ngeo + ol-cesium + cesium
The embeded ol3 supports reprojection when you navigate in 2D.
Unfortunatly not but i will try to put one more recent version that i have
somewhere (but not last version of ol for the reasons i mentionned earlier).
Ian
won't work.
What you can try:
it
seems
libs
built,
the
do
Ian
Ian Turton
s/geonetwork
*camptocamp*
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
Ian Turton
*camptocamp*
*Florent Gravin*
0479444492
In https://github.com/geonetwork/core-geonetwork/tree/ngeo there is a new
version of ngeo from october 2016.
Will test it a bit and merge soon in develop.
On Thu, Jun 15, 2017 at 11:32 AM, Florent Gravin <
Ian
won't work.
What you can try:
now it
seems
libs
built,
into the
packaging
would do
Ian
Ian Turton
s/geonetwork
*camptocamp*
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
Ian Turton
*camptocamp*
*Florent Gravin*
0479444492
*camptocamp*
*Florent Gravin*
0479444492
