[GeoNetwork-users] Upload size limit and data directory
Dear Geonetwork users and gurus,
after reading the documentation, a lot of trial and error with different versions from 3.7-3.10.2 (as geonetwork.war archive) I can't get the limit of about 100 MB for uploading and changing the data directory. Even reading the archived mailing list didn't help me.
The system is installed on a Xubuntu 18.04 VM, OpenJDK Runtime Environment (build 1.8.0_242-8u242-b08-0ubuntu3~18.04-b08), Apache Tomcat/9.0.16.
Increasing the limit in the config.xml file does not work:
<general>
<!-- Size must be in megabyte (integer), 100MB by default -->
<maxUploadSize>500</maxUploadSize>
<uploadDir>/var/lib/geonetwork_data/tmp</uploadDir>
<debug, true, debug.
</general>
Is this setting now outdated and no longer works in version 3 or higher?
Changing the data directory as described in Docs " Maintainer guide " Installing the application " Customizing the data directory did not help. Both CATALINA_OPTS=" -Dgeonetwork.dir=/var/lib/geonetwork_data" and JAVA_OPTS="-Dgeonetwork.dir=/var/lib/geonetwork_data" do not work.
But also changes in config-spring-geonetwork.xml like:
<bean id="GeonetworkDataDirectory" class="org.fao.geonet.kernel.GeonetworkDataDirectory" lazy-init="true">
<property name="systemDataDir" ref="GNSystemDataDir"/>
<property name="schemaPluginsDir" ref="GNSchemaPluginsDir"/>
</bean>
<bean id="GNSystemDataDir" class="java.nio.file.Paths" factory-method="get">
<constructor-arg index="0" value="/var/lib/geonetwork_data"/>
<constructor-arg index="1"><array /></constructor-arg>
</bean>
<bean id="GNSchemaPluginsDir" class="java.nio.file.Paths" factory-method="get">
<constructor-arg index="0" value="/var/lib/geonetwork_data/config/schema_plugins"/>
</bean>
<bean id="multipart resolver"
class="org.springframework.web.multipart.commons.CommonsMultipartResolver">
<property name="maxUploadSize" value="500000000"/>
</bean>
have no effect.
Does that work with the config-spring-geonetwork.xml file only if you compile the source code?
Would it work with these lines of code or is something missing?
Best regards
Viktor
So you get an exception like
{"message":"MaxUploadSizeExceededException","code":"max_file_exceeded","description":"Maximum
upload size of 50000000 bytes exceeded; nested exception is
org.apache.commons.fileupload.FileUploadBase$SizeLimitExceededException:
the request was rejected because its size (90494573) exceeds the configured
maximum (50000000)"} ?
Tomcat/9.0.16.
  <general>
default -->
  </general>
    </bean>
    </bean>
    </bean>
    </bean>
have no effect.
It maybe the case. You could try updating the file in
WEB-INF/lib/services-3.10.X.jar
and restart.
I'll look into moving that property to config.properties to make it easier
to customize.
Cheers.
Francois
Best regards
Viktor
GeoNetwork-users mailing list
Hi guys,
are there any more suggestions to the mentioned problem ? I also want to increase the upload size following the docs like here:
'By default, the maximum file size is set to 100Mb. This limit is set in source file /services/src/main/resources/config-spring-geonetwork.xml <https://github.com/geonetwork/core-geonetwork/tree/master//services/src/main/resources/config-spring-geonetwork.xml&gt; with the parameter |maxUploadSize|.'
But I have no such file in this location and the one with the same name I can find does not include this config lines.
Has this moved to some other file(s)?
Thx again and cheers
Andreas
Am 16.04.2020 um 12:43 schrieb Viktor Stroh:
<general>
</general>
</bean>
</bean>
</bean>
 &lt;property name=&quot;maxUploadSize&quot; value=&quot;500000000&quot;/&gt;
</bean>
have no effect.
Best regards
Viktor
Andreas Böhme
Techniker/Technician
Landschaftsökologie/Computational Landscape Ecology
Helmholtz-Zentrum für Umweltforschung GmbH - UFZ
Helmholtz Centre for Environmental Research GmbH - UFZ
Permoserstraße 15, 04318 Leipzig, Germany
Phone +49 341 235 1058
andreas.boehme@anonymised.com, www.ufz.de
Sitz der Gesellschaft/Registered Office: Leipzig
Registergericht/Registration Office: Amtsgericht Leipzig
Handelsregister Nr./Trade Register Nr.: B 4703
Vorsitzender des Aufsichtsrats/Chairman of the Supervisory Board: N.N.
Wissenschaftlicher Geschäftsführer/Scientific Managing Director:
Prof. Dr. Georg Teutsch
Administrative Geschäftsführerin/Administrative Managing Director:
Dr. Sabine König
Vermeiden Sie unnötige Ausdrucke./Think before printing.
Informationen aus der Wissenschaft (z.B. Veranstaltungshinweise, Projektangaben, Publikationen,
Bücher)
Hello, Andreas,
I'm guessing you installed the final compiled geonetwork.war archive? I could not increase the upload limit on the compiled version.
I downloaded the source code from the Git server and compiled it using maven. With the source code version, upload limit can be changed in the file you specify by changing the "maxUploadSize" parameter.
Best regard
Viktor
Am 30.04.20 um 11:49 schrieb Andreas Böhme:
Hi guys,
Andreas
_________________________________________
Viktor Stroh
Institut für Geodäsie und Geoinformation
Bereich der Geoinformation
Universität Bonn
Meckenheimer Allee 172
53115 Bonn
Tel: +49(0)228 73-1763
Fax: +49(0)228 73-1753
EMail: stroh@anonymised.com
Hi, guys,
after much trial and error, I found my own answers. If any of you know other alternatives, please let me know.
I could only increase the upload limit if I edit the file "services/src/main/resources/config-spring-geonetwork.xml" in the source code version and then compile the source code using maven.
Changing the data directory unfortunately does not work under Tomcat 9, or does it work for you?
When I installed Tomcat 8.5 under Ubuntu from the official repository instead of Tomcat 9, the parameter "CATALINA_OPTS=" -Dgeonetwork.dir=/var/lib/geonetwork_data" was accepted.
Best regard
Viktor
Am 16.04.20 um 12:43 schrieb Viktor Stroh:
Hi guys,
can someone (Jose, Paul, Jo, Francois et al.) pls approve this. Is this really the way to go ? It would be really great if there is another solution to this.
Andreas
Am 03.05.2020 um 23:25 schrieb Viktor Stroh:
Hello, Andreas,
Best regard
Viktor
Hi guys,
Andreas
Andreas Böhme
Dr. Sabine König
Bücher)
maybe you can test Francois proposal that he posted on April 16:
You could try updating the file in WEB-INF/lib/services-3.10.X.jar
and restart.
I'll look into moving that property to config.properties to make it easier to customize.
greetings
Viktor
Am 04.05.20 um 13:30 schrieb Andreas Böhme:
Hi guys,
Andreas
Hello, Andreas,
Best regard
Viktor
Thx Viktor,
I didnt't scroll that far down...my fault :wink:
Will try and post if it was successful.
Andreas
Am 04.05.2020 um 17:46 schrieb Viktor Stroh:
and restart.
greetings
Viktor
Hi guys,
Andreas
Hello, Andreas,
Best regard
Viktor
Andreas Böhme
Dr. Sabine König
Bücher)
Dear list,
I want to build geonetwork from source to increase the upload limit to our file store.
When I clone the repository, how do I proceed with the version I need, in my case 3.10.2?
How do I figure out which version I just cloned?
Thx and regards
Andreas
Am 05.05.2020 um 09:35 schrieb Andreas Böhme:
Thx Viktor,
Andreas
and restart.
greetings
Viktor
Hi guys,
Andreas
Hello, Andreas,
Best regard
Viktor
Andreas Böhme
Dr. Sabine König
Bücher)
Dear list,
Thx and regards
Andreas
Hi Andreas,
I believe that you will only be able to specify the 3.10.x branch- you
won't be able to specify 3.10.2.
If you follow the instructions at
https://geonetwork-opensource.org/manuals/trunk/en/maintainer-guide/installing/installing-from-source-code.html
then in the section "clone repository and build", after cloning and
changing to the correct directory, use the following to checkout the
3.10.x branch:
git checkout 3.10.x
Then make your changes. When you're ready to build, continue with the
rest of the instructions.
Hope this helps,
Jo
On Wed, Aug 12, 2020 at 11:03 AM Andreas Böhme <andreas.boehme@anonymised.com..> wrote:
Dear list,
our file store.
in my case 3.10.2?
Thx and regards
Andreas
Jo Cook
t:+44 7930 524 155/twitter:@archaeogeek
Please note that currently I do not work on Friday afternoons. For
urgent responses at that time, please visit
support.astuntechnology.com or phone our office on 01372 744009
*Sign up to our mailing list
<https://astuntechnology.com/company/#email-updates&gt; for updates on news,
products, conferences, events and training*
Astun Technology Ltd,
Epsom Square Centre, 6-7 The Derby Square, Epsom, Surrey, KT19 8AG, UK
t:+44 1372 744 009 w: astuntechnology.com <http://astuntechnology.com/&gt;
twitter:@astuntech <https://twitter.com/astuntech&gt;
iShare - enterprise
geographic intelligence platform <https://astuntechnology.com/ishare/&gt;
GeoServer, PostGIS and QGIS training
<https://astuntechnology.com/training-courses/&gt;
Helpdesk and customer
portal
<https://astuntech.atlassian.net/wiki/spaces/ISHAREHELP/pages/364970043/Astun+Technology+Support+Portal&gt;
Company registration no. 5410695. Registered in England and Wales.
Registered office: 120 Manor Green Road, Epsom, Surrey, KT19 8LN VAT no.
864201149.
Thx Jo,
this could help, but I am no developer and my GIT skills are on a low level. When I checkout the branch and commit my changes the build process does not work and I get an error.
Any advice on that?
Thx and greets
Andreas
Am 12.08.2020 um 12:20 schrieb Jo Cook:
Hi Andreas,
3.10.x branch:
git checkout 3.10.x
Hope this helps,
Jo
On Wed, Aug 12, 2020 at 11:03 AM Andreas Böhme <andreas.boehme@anonymised.com1...> wrote:
Dear list,
our file store.
in my case 3.10.2?
Thx and regards
Andreas
Andreas Böhme
Dr. Sabine König
Bücher)
Hi Andreas,
I would make sure you can build it from source before making any of
your own changes. Then if you still get an error you know it's not
your changes that have caused it! If you still get an error, then
include that when you ask on the mailing list as well.
All the best
Jo
On Wed, Aug 12, 2020 at 1:53 PM Andreas Böhme <andreas.boehme@anonymised.com.> wrote:
Thx Jo,
Any advice on that?
Thx and greets
Andreas
> Hi Andreas,
> 3.10.x branch:
> git checkout 3.10.x
> Hope this helps,
> Jo
> On Wed, Aug 12, 2020 at 11:03 AM Andreas Böhme <andreas.boehme@anonymised.com181...> wrote:
>> Dear list,
>> our file store.
>> in my case 3.10.2?
>> Thx and regards
>> Andreas
>> _______________________________________________
Andreas Böhme
Dr. Sabine König
Bücher)
Jo Cook
iShare - enterprise
portal
864201149.
Hi Andreas
After the clone, you can checkout the tag with the following commands:
git checkout 3.10.2
If you checkout submodules also, use the following to update them:
git submodule update --force
Jose García
On Mon, Aug 10, 2020 at 4:52 PM Andreas Böhme <andreas.boehme@anonymised.com.> wrote:
Dear list,
our file store.
in my case 3.10.2?
Thx and regards
Andreas
> Thx Viktor,
> Cheers
> Andreas
>>> and restart.
>> greetings
>> Viktor
>>> Hi guys,
>>> Cheers
>>> Andreas
>>>> Hello, Andreas,
>>>> version.
>>>> parameter.
>>>> Best regard
>>>> Viktor
Andreas Böhme
Dr. Sabine König
Bücher)
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/&gt;Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664>Please consider the environment before printing
this email.*
