Hi Jose,
Thanks for this fix which solves the keyword issue.
With respect to Inspire related functionalities, the search by Annex number is not working even after applying your fix. Could it be fixed also in 2.6.1?
Thanks for your support and quick response.
Best regards,
Paul
Sent: Friday, October 01, 2010 3:19 PM
To: Paul Hasenohr
Cc: geonetwork-users Users
Subject: Re: [GeoNetwork-users] use of Inspire search options in GN2.6.0
Hi
The problem seem caused by a latest change done to move INSPIRE setting from a config file (config-gui.xml) to the GUI settings. The search code is using the correct GUI setting, but the indexing code seem using the old config setting.
You can get it working adding also the old setting. Edit the file web/geonetwork/WEB-INF/config-gui.xml and add the inspire parameter:
<config>
<inspire>1</inspire>
You'll need to restart GeoNetwork and reindex the metadata.
This is temporal, until released 2.6.1. Going to commit a fix, so indexing code also uses the GUI setting as expected.
My apologies about this.
Jose García
On Fri, Oct 1, 2010 at 2:41 PM, jose garcia <josegar74@...54...<mailto:josegar74@…54…>> wrote:
Hi Paul
Going to check creating a sample metadata with INSPIRE keywords to verify. Will let you know.
Jose García
On Fri, Oct 1, 2010 at 2:33 PM, Paul Hasenohr <Paul.Hasenohr@...751...<mailto:Paul.Hasenohr@…751…>> wrote:
Hi Jose,
I reindexed the metadata but it does not change anything. “Land cover” is listed as keyword in the Keywords menu of the search interface and selecting it returns 18 results but ticking Land cover under Annex II returns 0 result.
Do you have another suggestion?
Thanks.
Best regards,
Paul
Sent: Friday, October 01, 2010 2:22 PM
To: Paul Hasenohr
Hi Paul
If INSPIRE search option is enabled in administration settings, GeoNetwork uses the keywords introduced in the metadata to match against the INSPIRE keywords. Your metadata keyword seem ok.
The problem can be if you created the metadata previously to enable the INSPIRE option. Then a reindex of metadata is required (in administration page also).
I have to check for next 2.6.x version to do the reindexing automatically when enable/disable the INSPIRE option so should be transparent for the user.
Please try this to see if works correctly after the reindex.
Jose García
On Fri, Oct 1, 2010 at 10:37 AM, Paul Hasenohr <Paul.Hasenohr@...751...<mailto:Paul.Hasenohr@…751…>> wrote:
Hello,
I would like to know the requirements for using the Inspire search options in Geonetwork 2.6.0. I have inserted Inspire compliant metadata into the catalogue but searches using Inspire criteria do not return any result.
I copy below the Inspire theme section of a metadata record:
<gmd:descriptiveKeywords>
<gmd:MD_Keywords>
<gmd:keyword>
<gco:CharacterString>Land cover</gco:CharacterString>
</gmd:keyword>
<gmd:thesaurusName>
<gmd:CI_Citation>
<gmd:title>
<gco:CharacterString>GEMET - INSPIRE themes, version 1.0</gco:CharacterString>
</gmd:title>
<gmd:date>
<gmd:CI_Date>
<gmd:date>
<gco:Date>2008-06-01</gco:Date>
</gmd:date>
<gmd:dateType>
<gmd:CI_DateTypeCode codeList="http://www.isotc211.org/2005/resources/codeList.xml#CI_DateTypeCode" codeListValue="publication"/>
</gmd:dateType>
</gmd:CI_Date>
</gmd:date>
</gmd:CI_Citation>
</gmd:thesaurusName>
</gmd:MD_Keywords>
</gmd:descriptiveKeywords>
Does GN expect e.g. the Citation to be formatted in a specific way to identify it as an Inspire keyword?
I could not find any information about this in the documentation therefore any help would be appreciated.
Best regards,
Paul
Paul Hasenohr
European Environment Agency
Kongens Nytorv 6
DK-1050 Copenhagen
Denmark
Tel: +45 33 36 72 58
paul.hasenohr@...751...<mailto:paul.hasenohr@…751…>
Start uncovering the many advantages of virtual appliances
and start using them to simplify application deployment and
accelerate your shift to cloud computing.
http://p.sf.net/sfu/novell-sfdev2dev
GeoNetwork-users mailing list
GeoNetwork-users@lists.sourceforge.net<mailto:GeoNetwork-users@lists.sourceforge.net>
