Hello,
I have used the docbook document "GeoNetworkv2.1-QuickStartGuide.xml" as
base to create a documentation for a customised installation of Geonetwork.
Regarding what i see creating my own documentation, i have some comment
about the docbook.
1) About the geographic search :
as example :
<listitem>
<para>If you choose <emphasis role="bold">Spatial search
type</emphasis> <citetitle>is</citetitle> “Country”, only maps for
the selected country will be displayed. In other words, a city map
within that country will not show in the output results.</para>
</listitem>
The term maps is always specified but i think it can concern all kind of
data description.
So maybe “metadata” is better than the term "maps".
2) On the when category the part concerning the "Group", "kind" is not
present on the help
A text like that is maybe convenient :
It is possible to limit your queries to only one source of metadata Group
originator,.simply select the category you wish in from the related
drop-down list, otherwise leave this field to Any .
It is also possible to limit your queries to only one kind of
metadata,.simply select the kind you wish (Metadata for consultation or
Template for creation )in from the related drop-down list.
3) The steps in more detail (Line 1453 i do not see more detail )
may be more detail if using the advanced search to find a specific template.
4) Entering Metadata for your Map
Line 1726
As we mentioned in the introduction to this guide, GNos provides tools to
describe any type of geographic data (verctor...
verctor >> vector
line 1737
additonal information collected
additonal >> additional
5) Line 1868
<para><emphasis role="bold">Data Quality</emphasis>: Specify the hierarchal
level of the data (<emphasis role="bold">
hierarchal >> hierarchical
6) Line 2031
<para>Finally, you can upload the dataset stored on your local
computer and then create a link between data and related
description.
Files in whatever format can be uploaded: doc, PDF, images, vector
layers, etc. For the latter the distribution in a compressed file is
recommended. You can include the verctor data...
verctor >> vector
7) Line 2126
<para>For instance, you can fdefine
fdefine >> define
8) Line 2292
<para>The main part of the page <emphasis role="bold">Import XML
Formatted Metadata</emphasis> that is displayed (figure 7.3 b) is the
<emphasis role="bold">Metadata</emphasis> text area, where the user
can
paste the XML metadata to import. Below this, there is the <emphasis
role="bold">Type</emphasis> choise,
choise >> Choice
9) Line 2305
<emphasis role="bold">Insert</emphasis> button
the metadata is imported into the system; please note that all links
to
external files, for istance
istance >> instance
10) Line 3274
<entry>Titel</entry>
titel >> title
In addition of this corrections i think that a part concerning the thesaurus
for the user during the metadata creation is missing.
It is nearly present on the administration documentation. it may be a good
thing to integrate it on the user documentation.
Fabien Bachraty
FBachraty wrote:
Hello,
I think there is a user documentation planned or actually in creation for
the release 2.1 isn't it ?
I find in the geonetwork/trunk/docs/docbook a quickstart docbook and the
content look very interesting !
I would like to know if it will be publish soon or not. Because i have to
do a documentation for an installation planned for the 1 January.
So even if this documentation is not completed, it will be very
appreciated if an xsl can be publish to see the current content on html or
pdf format.
Is it possible ?
Thank you very much
Fabien Bachraty.
View this message in context: http://www.nabble.com/User-documentation-for-Geonetwork-2.1-tp13993311s18419p14275892.html
Sent from the geonetwork-users mailing list archive at Nabble.com.
