[GeoNetwork-users] Using ftp for download
Hi
I am Macharia from Nairobi, Kenya. I've installed Geonetwork on Windows
Server 2008.
I have ftp links that I want to use as the online resource i.e "File for
download through FTP".
http://osgeo-org.1803224.n2.nabble.com/file/n6808378/ftp.bmp
However when i choose this option, the download button that appears in the
particular metadata record is not there.
http://osgeo-org.1803224.n2.nabble.com/file/n6808378/ftp2.bmp
My question is whether it is possible to use the ftp links and still have
the download button associated with the metadata record available.
Regards
Macharia Kabiro.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-ftp-for-download-tp6808378p6808378.html
Hi Macharia,
Could be that the privileges to download are not set.
Open the metadata record and select the 'Privileges' button
and check that the download option is ticked for groups
you are granting permission to download.
HTH
Andrew
----- Original Message ----- From: "pmacharia" <pmkabiro@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Monday, September 19, 2011 11:45 PM
Subject: [GeoNetwork-users] Using ftp for download
Hi
Server 2008.
Regards
Macharia Kabiro.
BlackBerry&reg; DevCon Americas, Oct. 18-20, San Francisco, CA
Learn about the latest advances in developing for the
BlackBerry&reg; mobile platform with sessions, labs & more.
See new tools and technologies. Register for BlackBerry&reg; DevCon today!
http://p.sf.net/sfu/rim-devcon-copy1
GeoNetwork-users mailing list
Thanks for the response Andrew, but the download option is checked, so I
don't think its the problem.
Macharia.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-ftp-for-download-tp6808378p6811406.html
Hi Macharia,
this is a known issue, as i read some times ago.
Maybe here you can find something interesting
http://osgeo-org.1803224.n2.nabble.com/Download-data-button-option-for-batch-imported-metadata-tabs-td5919507.html#a5945267
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Using-ftp-for-download-tp6808378p6848771.html
