[GeoNetwork-users] Using Tomcat on a server
After installation geonetwork resides in C:\Geonetwork\... We want now to
use Tomcat as webserver. We have tried to create geonetwork.xml and put it
into ...Catalina\localhost folder. Tomcat does not, however, recognize
geonetwork. The only way to success has been to copy geonetwork under Tomcat
webapps folder. Why? We would like to not to do this copy operation.
Arto
We've had no problem deploying by means of Tomcat Context files for several years now, on many different servers with different versions of GN and Tomcat. Please list your geonetwork.xml file.
A. Soroka
Digital Research and Scholarship R & D
the University of Virginia Library
Arto
Download Intel® Parallel Studio Eval
Try the new software tools for yourself. Speed compiling, find bugs
proactively, and fine-tune applications for parallel performance.
See why Intel Parallel Studio got high marks during beta.
http://p.sf.net/sfu/intel-sw-dev
GeoNetwork-users mailing list
in the Tomcat configuration...... you can find some file such as
server.xml....... and other...
in server.xml...... I thing.... there is the tag context, add a new
context for GeoNetwork, and it will work (add another context also for
intermap)!!!!
2010/3/31 Arto Vuorela <arto.k.vuorela@anonymised.com>:
Arto
Download Intel&#174; Parallel Studio Eval
Ing. Francesco D'Amore
blog: www.marinajonica.org
linkedin: http://www.linkedin.com/in/francescodamore
Consiglio Nazionale delle Ricerche - Istituto di Inquinamento Atmosferico (IIA)
Ph. D. Student at University of Calabria - DEIS
This (putting Context elements into server.xml) is -explicitly, specifically- discouraged by the Tomcat project.
See the fourth paragraph here:
http://tomcat.apache.org/tomcat-6.0-doc/config/context.html#Introduction
It will work, for now, but it is deprecated.
A. Soroka
intermap)!!!!
Arto
Thank you for this information.........
2010/3/31 <ajs6f@anonymised.com>:
A. Soroka
intermap)!!!!
Arto
ok....... you can use the same procedure but put this Geonetwork and
the Intermap context in In the $CATALINA_BASE/conf/context.xml
this is not deprecated and has the same effect.
Thank you
2010/3/31 Francesco D'Amore <francesco.damore@anonymised.com>:
A. Soroka
intermap)!!!!
Arto
While it's good to have an alternative solution, if I were having this problem, I would want to determine why my Tomcat instance isn't behaving according to spec. It may point to an underlying instability.
A. Soroka
Thank you
A. Soroka
intermap)!!!!
Arto
