Hi List,
when I import data in XML in the ISO19139 format using batch import, single XML file or whole folder content, the metadata is not validated.
So the metadata is getting imported with errors, for example when changing <gmd:title> with <gmd:title2> it's getting imported also.
Thanks in advance for any hint how to turn on validation of batch import / insert metadata.
Jan
Hi Jan,
I´m new to geonetwork so I would say that
<gmd:title2 aren´t working because title2 does not exist at the namespace.
the files for validation are at web/geonetwork/xml/validation. I think it
doesn´t matter if you have a batch import or a single matadata import.
Sorry I can help you any further.
best regards
Sarah
Jan Schorn-3 wrote:
Hi List,
/ insert metadata.
Jan
Come build with us! The BlackBerry® Developer Conference in SF, CA
is the only developer event you need to attend this year. Jumpstart your
developing skills, take BlackBerry mobile applications to market and stay
ahead of the curve. Join us from November 9-12, 2009. Register
now!
http://p.sf.net/sfu/devconf
GeoNetwork-users mailing list
View this message in context: http://n2.nabble.com/Validate-Metadata-tp3684787p3685000.html
Hi, it doesn't matter if number or not (gmd:titleTitle works ...), seems that there is no validation by default and we don't know how to turn it on.
Thanks for any hints.
Jan
Sarah Schuessler wrote:
hi jan,
do you have any further information of that until now?
Perhaps the "2" (or numbers at all) is left outside and in fact of that it worked. Don´t really know.
best regards
Sarah
*Von:* Jan Schorn <js@anonymised.com>
*An:* Sarah_S <Sarah_flip@anonymised.com>
*Gesendet:* Montag, den 21. September 2009, 15:38:45 Uhr
*Betreff:* Re: [GeoNetwork-users] Validate Metadata
Hi Sarah,
thanks for thinking about the question - and thats the point!
It should't work as title2 doesn't exist in namespace, but it is working in both cases ...
best regards,
Jan
Sarah_S wrote:
> Hi Jan,
> I´m new to geonetwork so I would say that <gmd:title2 aren´t working because title2 does not exist at the namespace.
> best regards
> Sarah
> Jan Schorn-3 wrote:
> >> Hi List,
>> Jan
>> developing skills, take BlackBerry mobile applications to market and stay ahead of the curve. Join us from November 9-12, 2009. Register
>> now!
>> _______________________________________________
>> GeoNetwork-users@lists.sourceforge.net <mailto:GeoNetwork-users@lists.sourceforge.net>
