[GeoNetwork-users] validateJarFile not loaded
Hi All,
Sorry for cross posting.
I now seem to GN version 2.7 snapshot revision r8695 with ANZMEST
schemaplugins revision r8650.p migrated and running on the new server.
I am now debugging or documenting the errors.
When I start up GN I get the following in the catalina.out file:
INFO:
validateJarFile(/data/jakarta/geonetwork-asdd/webapps/geoserver/WEB-INF/lib/servlet-api-2.4.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
Is this an issue? Is it my setup or is it something that GN 2.7 does?
Thanks.
John Hockaday
Hi John,
This is not a big issue. Geonetwork has an incorrect pom configuration. the jar should be marked as provided in the pom.xml so that it is used for compilation and not deployment. It might be there for GAST, I am not sure but the correct thing is for it not to be included in the war because the web server container contains the actual files. However it is just ignored by tomcat so it is in practice not an issue.
On Thu, Jun 7, 2012 at 7:59 AM, john.hockaday <john.hockaday@anonymised.com> wrote:
Hi All,
INFO:
Thanks.
John Hockaday
Live Security Virtual Conference
Exclusive live event will cover all the ways today’s security and
threat landscape has changed and how IT managers can respond. Discussions
will include endpoint security, mobile security and the latest in malware
threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
GeoNetwork-devel mailing list
