Hi
I'm getting bizarre issues in a batch import if I select the validate
option:
*If I remove the metadata schemaLocation (using local xsd). I get this:*
- cvc-elt.4.2: Cannot resolve 'DQ_DomainConsistency_Type' to a type
definition for element 'gmd:DQ_DomainConsistency'. (Element:
gmd:DQ_DomainConsistency with parent element: gmd:report)
cvc-elt.4.2: Cannot resolve 'DQ_ConformanceResult_Type' to a type
definition for element 'gmd:DQ_ConformanceResult'. (Element:
gmd:DQ_ConformanceResult with parent element: gmd:result)
But the same metadata, in XMLSpy setting the schemaLocation to the
GeoNetwork schema folder validates properly. Honestly, I don't think XMLSpy
is hiding any error, looks some issue in GeoNetwork.
*If I keep the original schemaLocation in the metadata:*
xsi:schemaLocation="http://www.isotc211.org/2005/srv
http://schemas.opengis.net/iso/19139/20060504/srv/srv.xsd
http://www.isotc211.org/2005/gmd
http://schemas.opengis.net/iso/19139/20060504/gmd/gmd.xsd"
XMLSpy validates properly also.
GeoNetwork takes quite more time (due to remove xsd stuff I guess) and
reports a long list of issues. As a summary of the first ones:
schema_reference.4: Failed to read schema document
'../gts/temporalObjects.xsd', because 1) could not find the document; 2)
the document could not be read; 3) the root element of the document is not
<xsd:schema>. (Element: gmd:MD_Metadata with parent element: Unknown)
schema_reference.4: Failed to read schema document '
http://schemas.opengis.net/iso/19139/20060504/gsr/gsr.xsd’, because 1)
could not find the document; 2) the document could not be read; 3) the root
element of the document is not <xsd:schema>. (Element: gmd:MD_Metadata with
'../gmd/metadataExtension.xsd', because 1) could not find the document; 2)
schema_reference.4: Failed to read schema document '../gmd/content.xsd',
because 1) could not find the document; 2) the document could not be read;
3) the root element of the document is not <xsd:schema>. (Element:
... (MORE ISSUES)
But what is more surprising, is that retrying again the import with
validation enabled, it outputs only this:
Any idea why these differences and how to make the validation work properly
. Tested with 2.10.3 and 2.10.X branch code.
Jose García
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcíaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
