I downloaded and installed the last beta 2 but I have a problem when I
would like to create new metadata. When I click "Create", nothing occurs
! I have a error in FireBug : "$F is not defined"
I try with IE, same problem.
I come back with the previous beta and I don't have these problem.
Pensez ? l'environnement avant d'imprimer ce message
Think Environment before printing
Le contenu de ce m?l et de ses pi?ces jointes est destin? ? l'usage exclusif du (des) destinataire(s) d?sign?(s)
comme tel(s).
En cas de r?ception par erreur, le signaler ? son exp?diteur et ne pas en divulguer le contenu.
L'absence de virus a ?t? v?rifi?e ? l'?mission, il convient n?anmoins de s'assurer de l'absence de
contamination ? sa r?ception.
The contents of this email and any attachments areconfidential. They are intended for the named recipient(s)
only.
If you have received this email in error please notifythe system manager or the sender immediately and do not
disclose the contents to anyone or make copies.
eSafe scanned this email for viruses, vandals and malicious content.
I've got the following problem: I want to send a CSW-request to
Geonetwork to get the online resource link (i.e. the link where the
image data is stored). My Database is filled with ISO19115 and ISO19139
entries, but geonetwork only returns Dublin Core with no entry for the
online resource. Is there a possibility to get the online ressource with
Dublin Core or that geonetwork returns the original format (i.e.
ISO19115) ?
you can get the real metadata only for ISO19139 schema format
because that it the one that provides a csw profile.
To do that, perform a GetRecords with the parameter:
outputSchema="csw:IsoRecord"
ISO19115) ?
I am Ana and I am new using Geonetwork, I am a bit lost . I would like
have your help.
I have the same problem which is asked by Nico: I want to send a CSW-request
to Geonetwork to get the online resource link. My Database is filled with
ISO19115 and I have tried it with outputSchema="csw:IsoRecord" but I don't
understand the response received and I think it doesn't reurn the online
resource.
Is there any possibility to get the online resource link with other
standard?
Thank you very much.
Ana
Andrea Carboni-2 wrote:
Hi Nico,
ISO19115) ?
