De: Lionel Menard <lionel.menard@anonymised.com>
Objet: WAF Harvest
Date: 6 avril 2018 à 11:27:12 UTC+2
À: geonetwork-users@lists.sourceforge.net
Cc: Lionel Menard <lionel.menard@anonymised.com>[GeoNetwork Version: 2.10 and 3.2.1.0]
Hi, I tried to harvest the following WAF with the WAF harvest option:
http://www.neracoos.org/WAF/UMaine/iso/
I tried with both a 2.10 and 3.2.1.0 GeoNetwork versions and though the harvest process seems to end-up correctly I get an "Unknown Schema" message and no metadata records are created.
The log indicates the following:2018-03-07 10:39:30,286 WARN [ERDDAP_WAF] - Skipping metadata with unknown schema. Path is : http://www.neracoos.org/WAF/UMaine/iso/SOS_A01_optics_s3m_Historic_Realtime_Agg.xml
2018-03-07 10:39:31,006 WARN [ERDDAP_WAF] - Skipping metadata with unknown schema. Path is : http://www.neracoos.org/WAF/UMaine/iso/SOS_DSG_A01_AANDERAA_Historic_Realtime_Agg.xml…It apparently tells me that I need an extra schema to be associated with the xml data I want to harvest but I don't know how can I set this option in the harvest form I'm provided with in GeoNetwork harvest section.
Any help is very welcome.
Thanks in advance.
Lionel
Lionel MENARD, MINES ParisTech CS 10207 F-06904 Sophia Antipolis France Tel +33 493957423
