[GeoNetwork-users] WebDAV Harvesting
Hello,
I am trying to harvest the metadata records present in
http://www.webservice-energy.org/metadata/ using Geonetwork WebDav Option
and I get the following exception.
java.lang.Exception: HTTPException: null
at
org.fao.geonet.kernel.harvest.harvester.webdav.WebDavRetriever.open(WebDavRe
triever.java:104)
at
org.fao.geonet.kernel.harvest.harvester.webdav.WebDavRetriever.retrieve(WebD
avRetriever.java:57)
at
org.fao.geonet.kernel.harvest.harvester.webdav.Harvester.harvest(Harvester.j
ava:74)
at
org.fao.geonet.kernel.harvest.harvester.webdav.WebDavHarvester.doHarvest(Web
DavHarvester.java:167)
at
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexPr
ocessor.process(AbstractHarvester.java:379)
at
org.fao.geonet.kernel.MetadataIndexerProcessor.processWithFastIndexing(Metad
ataIndexerProcessor.java:39)
at
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester.harvest(AbstractHa
rvester.java:406)
Also can any one please explain if Web Accessible folder can be harvested
using WebDAV option in Geonetwork.
Looking forward your help.Thanks.
Regards
Kumaran
Hi Kumaran
I tried to access also the WebDav folder you provided from Cyberduck and Mac
Finder and get error connections. In Cyberduck I get *Method Not Allowed*.
Probably the WebDav is not configured properly in the server.
Time ago in a project I worked get similar issue and debugging GeoNetwork
got that was failing because the server was not setup properly and didn't
support PROPFIND method to query it. After configure the server properly the
harvester worked.
Check your server configuration to expose the folder as WebDav.
Jose García
On Fri, Aug 26, 2011 at 7:44 PM, Kumaran Narayanaswamy <
kumaran.narayanaswamy@anonymised.com> wrote:
Hello,****
and I get the following exception.****
at
org.fao.geonet.kernel.harvest.harvester.webdav.WebDavRetriever.open(WebDavRetriever.java:104)
at
org.fao.geonet.kernel.harvest.harvester.webdav.WebDavRetriever.retrieve(WebDavRetriever.java:57)
at
org.fao.geonet.kernel.harvest.harvester.webdav.Harvester.harvest(Harvester.java:74)
at
org.fao.geonet.kernel.harvest.harvester.webdav.WebDavHarvester.doHarvest(WebDavHarvester.java:167)
at
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor.process(AbstractHarvester.java:379)
at
org.fao.geonet.kernel.MetadataIndexerProcessor.processWithFastIndexing(MetadataIndexerProcessor.java:39)
at
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester.harvest(AbstractHarvester.java:406)
using WebDAV option in Geonetwork.****
Looking forward your help.Thanks.****
Regards****
Kumaran****
EMC VNX: the world's simplest storage, starting under $10K
The only unified storage solution that offers unified management
Up to 160% more powerful than alternatives and 25% more efficient.
Guaranteed. http://p.sf.net/sfu/emc-vnx-dev2dev
GeoNetwork-devel mailing list
Jose,
The link that I had sent is not a WebDAV Server. It is a Web Accessible
Folder. Is there a way in Geonetwork where we can harvest the metadata files
that are present in Web Accessible folder. One option that I see is download
these files to Server and then use local folder harvesting. Is there any
option where I can directly harvest from these web accessible folder in
geonetwork?
Regards
Kumaran
From: jose garcia [mailto:josegar74@anonymised.com]
Sent: Monday, August 29, 2011 1:59 PM
To: Kumaran Narayanaswamy
Cc: geonetwork-users@lists.sourceforge.net;
geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] WebDAV Harvesting
Hi Kumaran
Finder and get error connections. In Cyberduck I get Method Not Allowed.
harvester worked.
Jose García
<kumaran.narayanaswamy@anonymised.com> wrote:
Hello,
at
triever.java:104)
at
at
ava:74)
at
at
at
at
rvester.java:406)
Regards
Kumaran
Hi Kumaran
Not sure about Web Accessible Folder harvesting, but if doesn't use WebDav
protocol would need to develop a new harvester type to manage it.
I see you use IIS, should be possible to configure a WebDav resource so
works ok in GeoNetwork harvesting, but don't use too much about IIS (maybe
this can help: http://www.iis.net/download/webdav)
Other option, if you don't get it working is using Local file system
harvesting as you comment.
Jose García
On Mon, Aug 29, 2011 at 10:37 AM, Kumaran Narayanaswamy <
Jose,****
geonetwork?****
Regards****
Kumaran****
*From:* jose garcia [mailto:josegar74@anonymised.com]
*Sent:* Monday, August 29, 2011 1:59 PM
*To:* Kumaran Narayanaswamy
*Cc:* geonetwork-users@lists.sourceforge.net;
*Subject:* Re: [GeoNetwork-devel] WebDAV Harvesting****
Hi Kumaran****
Mac Finder and get error connections. In Cyberduck I get *Method Not
Allowed*. Probably the WebDav is not configured properly in the server.***
harvester worked.****
Check your server configuration to expose the folder as WebDav.****
Regards,****
Jose García****
kumaran.narayanaswamy@anonymised.com> wrote:****
Hello,****
at
at
at
at
at
at
at
Regards****
Kumaran****
http://sourceforge.net/projects/geonetwork****
Hello Jose,
The link that I provided was an example link to which we do not have access
to control the servers. The option now I see is to download the files to
local server and then use Local harvesting option.
On a side note when I define a harvester when I select the option Validate,
does the harvester check for both Schema Validation and Schematron
validation?
Regards
Kumaran
Sent: Monday, August 29, 2011 2:16 PM
Hi Kumaran
Jose García
Jose,
geonetwork?
Regards
Kumaran
Hi Kumaran
harvester worked.
Jose García
Hello,
at
triever.java:104)
at
at
ava:74)
at
at
at
at
rvester.java:406)
Regards
Kumaran
Hi Kumaran
The validation in harvester only validates xsd, no schematron.
Jose
On Mon, Aug 29, 2011 at 11:02 AM, Kumaran Narayanaswamy <
Hello Jose,****
local server and then use Local harvesting option.****
validation?****
Regards****
Kumaran****
*Sent:* Monday, August 29, 2011 2:16 PM
Hi Kumaran****
protocol would need to develop a new harvester type to manage it. ****
this can help: http://www.iis.net/download/webdav)****
harvesting as you comment.****
Regards,****
Jose García****
Jose,****
geonetwork?****
Regards****
Kumaran****
Hi Kumaran****
Regards,****
Jose García****
Hello,****
at
at
at
at
at
at
at
Regards****
Kumaran****
GeoNetwork has been modified in our version to expand the WebDAV module to include harvest of web directories of XML files. In particular, these are XML files in ISO 19139 or FGDC metadata format. George Mason University added this capability and would like to work with the committers to add this functionality to trunk.
Doug.
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat Tel/Fax:541 234-6326 Cell:703 459-5860
Great ....it will be good to have this feature committed in geonetwork...
Kumaran
-----Original Message-----
From: Douglas Nebert [mailto:ddnebert@anonymised.com]
Sent: Tuesday, August 30, 2011 3:32 AM
To: geonetwork-users@lists.sourceforge.net;
Subject: Re: [GeoNetwork-devel] [GeoNetwork-users] WebDAV Harvesting
harvested using WebDAV option in Geonetwork.****
Doug.
Douglas D. Nebert
Special Offer -- Download ArcSight Logger for FREE!
Finally, a world-class log management solution at an even better
price-free! And you'll get a free "Love Thy Logs" t-shirt when you
download Logger. Secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsisghtdev2dev
Dear Kai,
Yes you need commit access . You can contact the core developers of
geonetwork who can commit your patch to trunk.
I have copied Jose who is one of the core developers of geonetwork who can
help you to commit your patch.
Regards
Kumaran
Sent: Tuesday, August 30, 2011 6:27 PM
Cc: ddnebert@anonymised.com; ddnebert@anonymised.com; cyang3@anonymised.com; zgui@anonymised.com;
jxia3@anonymised.com
Dear Kumaran,
Sorry for bothering you. I wonder how I can commit the changes to the trunk?
Should I have the commit access? We added the function to the GeoNetwork
2.6.3 and it helped harvesting some WAF catalogs to our GEOSS Clearinghouse.
I'd like to create a patch based on the current version and commit it.
Thanks and best regards,
Kai
Joint Center for Intelligent Spatial Computing
703-395-2337
----- Original Message -----
From: Kumaran Narayanaswamy <kumaran.narayanaswamy@anonymised.com>
Date: Tuesday, August 30, 2011 0:49 am
Subject: Re: [GeoNetwork-users] [GeoNetwork-devel] WebDAV Harvesting
geonetwork...
Kumaran
George Mason Universityadded this capability and would like to work
Doug.
Douglas D. Nebert
GeoNetwork-users mailing list
