[GeoNetwork-users] what is the best way to migrate directory-items from one catalogue to other?
I have a catalogue from which i want to export a batch of directory items and import in another catalogue, any suggestions?
- the directory page does not offer a bulk export mechanism
- a harvest of subtemplates seems also dysfunctional (not sure if that’s a bad thing), if i add custom-criteria resulttype=subtemplates, it ignores it and just harvests the full catalogue
- build a script to call the api to upload snippets
- create a database insert script
In my case i had a text file with 60 directory items, each on a single line
I used this bash script to create individual files for each line
And then drag-dropped them in the import metadata upload field
i=0; while read LINE; do i=$((i+1)); ECHO "$LINE" > "$i.xml" ; done < conformance-snippets.xml
Hi Paul, maybe we should add MEF export of directory entries ?
Francois
Le ven. 26 juil. 2019 à 12:56, Paul van Genuchten <
GeoNetwork-users mailing list
