[GeoNetwork-users] what is the default root password for mysql on centos5.2
help
I want to configure my geonetwork on mysql database but once i install linux centos 5.2 it doesn't create a room for doing that during installation how then do i know the default root password .
Regards
Web master
ERMIS AFRICA
Box 17347
Nakuru - 20100
Tel +254 51 221 33 23
Mob. +254 725 885 889
Website http://www.ermisafrica.org
    or
          http://www.ermisafrica.com
the installer assumes your mysql has the username and password generated by
the installer.
You can see what the values are in
<installation-directory>/geonetwork/web/WEB-INF/config.xml -- search for
"mysql" in that file. You can also change the values here to what they
really are, if you have a pre-existing mysql database.
Kind regards
Heikki Doeleman
On Sat, Mar 14, 2009 at 3:36 PM, simon <simon@anonymised.com> wrote:
help
Regards
Web master
ERMIS AFRICA
Box 17347
Nakuru - 20100
               or
Apps built with the Adobe(R) Flex(R) framework and Flex Builder(TM) are
powering Web 2.0 with engaging, cross-platform capabilities. Quickly and
easily build your RIAs with Flex Builder, the Eclipse(TM)based development
software that enables intelligent coding and step-through debugging.
Download the free 60 day trial. http://p.sf.net/sfu/www-adobe-com
GeoNetwork-users mailing list
