[GeoNetwork-users] Where are all catalogue data and image thumbnails are stored?
Greetings
I have installed and used GeoNetworks in a CentOS server. Now, we will have to change server OS and I do not want to loose all information placed in Geonetwork (data catalogue + thumbnails). Where are they stored in order to do a back up copy and not loose that information?
Thanks
Best regards,
Antonio
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6690 (20111207) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
The metadata are stored in the database.
The place where the associated data (files for download, thumbnails) are
stored is defined in WEB-INF/config.xml, in the dataDir parameter.
Jean
2011/12/7 António Rocha <antonio.rocha@anonymised.com>
Greetings
Thanks
Best regards,
Antonio
http://www.eset.com
Cloud Services Checklist: Pricing and Packaging Optimization
This white paper is intended to serve as a reference, checklist and point
of
discussion for anyone considering optimizing the pricing and packaging
model
of a cloud services business. Read Now!
http://www.accelacomm.com/jaw/sfnl/114/51491232/
GeoNetwork-users mailing list
N'imprimez ce message qu'en cas de nécessité. Soyons éco-responsables !
Donnez une nouvelle dimension à vos données
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Port : +33 6 09 23 21 36
Skype : igejean
Information Géographique et Environnement
12 rue Arnaud Vidal
31000 Toulouse
France
Tel : +33 5 61 86 81 49
Fax : +33 5 61 86 09 23
Mail : contact@anonymised.com
Site web : www.ige.fr <http://wwww.ige.fr/&gt;
*L'actualité d'IGE sur RSS : *http://www.ige.fr/actualites/rss.php
*Localisez IGE dans WorldWind : *
worldwind://goto/world=Earth&lat=43.55519&lon=1.38256&alt=190&dir=26.7&tilt=60.3
- Afficher le texte des messages précédents -
Hi
Thanks Jean for your feedback but:
1- That parameter is defined as param name="dataDir" value="../../data" /> . What does this mean? I mean the ../../data ?
2- Where is stored the metadata that was inserted in GeoNetWork?
3- Is there any way to export the data catalogue and import it into other GeonetWork installatyion?
Thanks
Antonio
Jean Pommier (IGE) wrote:
The place where the associated data (files for download, thumbnails) are stored is defined in WEB-INF/config.xml, in the dataDir parameter.
Jean
2011/12/7 António Rocha <antonio.rocha@anonymised.com <mailto:antonio.rocha@anonymised.com>>
    Greetings
    Thanks
    Best regards,
    Antonio
    http://www.eset.com
    and point of
    packaging model
    <mailto:GeoNetwork-users@lists.sourceforge.net>
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
Mail : contact@anonymised.com <mailto:contact@anonymised.com>
*Localisez IGE dans WorldWind : *worldwind://goto/world=Earth&lat=43.55519&lon=1.38256&alt=190&dir=26.7&tilt=60.3
António Rocha
Aerospace & Defence Portugal
DEIMOS Engenharia, SA
Av. D. Joao II, Lt 1.17.01 - 10º, Ed. Torre Zen
1998-023 Lisboa, Portugal
Ph: +351 21 893 3010
Fax: +351 21 896 9099
http://www.deimos.pt
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6702 (20111211) __________
http://www.eset.com
Bom dia, Antonio,
1) If my memory is right, the path is relative to the geonetwork's root
directory. I mean, in your case, you have a directory
/usr/local/geonetwork/web/geonetwork. This is the root directory of the app.
Thus, ../../data is /usr/local/geonetwork/data
2) The metadat itself is stored in the database. If it's a McKoi (default)
database, I believe it is located in
/usr/local/geonetwork/web/geonetwork/WEB-INF/db/data but I'm not sure you
can migrate it easily by simple file copy (I had some troubles doing so,
when changing for one OS to another (linux to windows).
On a server, I believe it's not recommended to keep with a McKoi DB.
3) GAST gives you tools for such migration. Or you can export it all in MEF
format, and re-import it in your new catalog. But there are some caveats...
(see one of my last posts...)
Jean
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
Site web : www.ige.fr <http://wwww.ige.fr>
2011/12/12 António Rocha <antonio.rocha@anonymised.com>
Hi
Thanks
Antonio
Jean
antonio.rocha@anonymised.com**com.pt <antonio.rocha@anonymised.com>>>
   Greetings
   Thanks
   Best regards,
   Antonio
   http://www.eset.com
   and point of
   packaging model
   http://www.accelacomm.com/jaw/**sfnl/114/51491232/&lt;http://www.accelacomm.com/jaw/sfnl/114/51491232/&gt;
   ______________________________**_________________
   GeoNetwork-users@anonymised.com**sourceforge.net<GeoNetwork-users@anonymised.comurceforge.net>
   <mailto:GeoNetwork-users@**lists.sourceforge.net<GeoNetwork-users@anonymised.comts.sourceforge.net>
   https://lists.sourceforge.net/**lists/listinfo/geonetwork-**users&lt;https://lists.sourceforge.net/lists/listinfo/geonetwork-users&gt;
   http://sourceforge.net/**projects/geonetwork&lt;http://sourceforge.net/projects/geonetwork&gt;
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
*L'actualité d'IGE sur RSS : *http://www.ige.fr/actualites/**rss.php&lt;http://www.ige.fr/actualites/rss.php&gt;
*Localisez IGE dans WorldWind : *worldwind://goto/world=Earth&**
lat=43.55519&lon=1.38256&alt=**190&dir=26.7&tilt=60.3
António Rocha
http://www.eset.com
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
Hi Jean
I have tried to export using GAST but I get a "Connection refused" window. When I try to run Search in "Metadata Export" window Site ID is not populated neither group owner. And the retrieve button I get "Connection refused".
Anyone, any tips on using GAST?
Thanks
Antonio
Bom dia, Antonio,
1) If my memory is right, the path is relative to the geonetwork's root directory. I mean, in your case, you have a directory /usr/local/geonetwork/web/geonetwork. This is the root directory of the app.
2) The metadat itself is stored in the database. If it's a McKoi (default) database, I believe it is located in /usr/local/geonetwork/web/geonetwork/WEB-INF/db/data but I'm not sure you can migrate it easily by simple file copy (I had some troubles doing so, when changing for one OS to another (linux to windows).
3) GAST gives you tools for such migration. Or you can export it all in MEF format, and re-import it in your new catalog. But there are some caveats... (see one of my last posts...)
Jean
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
2011/12/12 António Rocha <antonio.rocha@anonymised.com <mailto:antonio.rocha@anonymised.com>>
    Hi
    Thanks
    Antonio
        Jean
        <mailto:antonio.rocha@anonymised.com>>>
           Greetings
        Now, we will
        information
        are they
        information?
           Thanks
           Best regards,
           Antonio
        of virus
           http://www.eset.com
           and point of
           packaging model
        <mailto:GeoNetwork-users@lists.sourceforge.net>>
        -- N'imprimez ce message qu'en cas de nécessité. Soyons
        éco-responsables !
        I G E
        Jean POMMIER
        *Directeur Associé*
        TIC - Webmapping 3D
        Port : +33 6 09 23 21 36 <tel:%2B33%206%2009%2023%2021%2036>
        Skype : igejean
        12 rue Arnaud Vidal
        31000 Toulouse
        France
        Tel : +33 5 61 86 81 49 <tel:%2B33%205%2061%2086%2081%2049>
        Fax : +33 5 61 86 09 23 <tel:%2B33%205%2061%2086%2009%2023>
        Site web : www.ige.fr <http://www.ige.fr> <http://wwww.ige.fr/&gt;
    -- António Rocha
    Ph: +351 21 893 3010 <tel:%2B351%2021%20893%203010>
    Fax: +351 21 896 9099 <tel:%2B351%2021%20896%209099>
    http://www.eset.com
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
__________ Information from ESET NOD32 Antivirus, version of virus signature database 6703 (20111212) __________
http://www.eset.com
Can't help you with GAST, sorry..
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
Hi Jean
refused".
Thanks
Antonio
Bom dia, Antonio,
/usr/local/geonetwork/web/**geonetwork. This is the root directory of
the app.
**geonetwork/WEB-INF/db/data but I'm not sure you can migrate it easily
Jean
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
   Hi
   Thanks
   Antonio
       Jean
       <mailto:antonio.rocha@anonymised.comcom.pt<antonio.rocha@anonymised.com>
       <mailto:antonio.rocha@anonymised.com**com.pt<antonio.rocha@anonymised.com>
          Greetings
       Now, we will
       information
       are they
       information?
          Thanks
          Best regards,
          Antonio
       of virus
          http://www.eset.com
          and point of
          packaging model
          GeoNetwork-users@anonymised.com**sourceforge.net<GeoNetwork-users@anonymised.comists.sourceforge.net>
       <mailto:GeoNetwork-users@**lists.sourceforge.net<GeoNetwork-users@lists.sourceforge.net>
users <https://lists.sourceforge.net/lists/listinfo/geonetwork-users&gt;
       éco-responsables !
       I G E
       Jean POMMIER
       *Directeur Associé*
       TIC - Webmapping 3D
       Port : +33 6 09 23 21 36 <tel:%2B33%206%2009%2023%2021%**2036>
       Skype : igejean
       12 rue Arnaud Vidal
       31000 Toulouse
       France
       Tel : +33 5 61 86 81 49 <tel:%2B33%205%2061%2086%2081%**2049>
       Fax : +33 5 61 86 09 23 <tel:%2B33%205%2061%2086%2009%**2023>
rss.php <http://www.ige.fr/actualites/rss.php&gt;
       *worldwind://goto/world=Earth&**lat=43.55519&lon=1.38256&alt=**
   -- António Rocha
   http://www.eset.com
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
http://www.eset.com
I G E
Jean POMMIER
*Directeur Associé*
TIC - Webmapping 3D
Skype : igejean
12 rue Arnaud Vidal
31000 Toulouse
France
