[GeoNetwork-users] Where is the xsl that presents the title of a object? [SEC=UNCLASSIFIED]
Hi Guys
Moved to 3.4.2
OK I found the XML error in my schema_plugins/iso19115-3/index-fields/index-subtemplate-fields.xsl file (mea culpa) and now have a title [of sorts]
Now I do get titles [but see below on import]
If I create a new record from template - all good
BUT
I've imported 1200 X ISO19115-3 records
Now I do get titles, but I also get the address: as in ["1st line of address","Title"]
     EG ["GPO 2182","Nutrient Status of Australian Agricultural Soils (1989-1999) pH (CaCl2) (0 - 15cm) ESRI Point ShapeFiles - point excluded from surface calculations"]
Any pointers on where the XML/XSL that is pulling that is or why?
e
[cid:image002.png@anonymised.com]
BLEYS Evert Mr
Data Manager
Australian Bureau of Agricultural and Resource Economics and Sciences
Department of Agriculture and Water Resources
GPO Box 858 Canberra City ACT Australia 2601
44 Mort St Braddon ACT 2612
Ph: +61 (0)2 6272 5627
Email: Evert.Bleys@anonymised.com
IMPORTANT - This email and any attachments have been issued by the Australian Government Department of Agriculture and Water Resources. The material transmitted is for the use of the intended recipient only and may contain confidential, legally privileged, copyright or personal information. You should not copy, use or disclose it without authorisation from the Department. It is your responsibility to check any attachments for viruses and defects before opening or forwarding them.
If you are not an intended recipient, please contact the sender of this email at once by return email and then delete both messages. Unintended recipients must not copy, use, disclose, rely on or publish this email or attachments. The Department of Agriculture and Water Resources is not liable for any loss or damage resulting from unauthorised use or dissemination of, or any reliance on, this email or attachments.
If you have received this e-mail as part of a valid mailing list and no longer want to receive a message such as this one, advise the sender by return e-mail accordingly. This notice should not be deleted or altered
(attachments)
