I'm struggling to print a WMTS base layer from my GeoNetwork 3.0.x install
- I've laid out the setup and errors in this StackExchange question (
http://gis.stackexchange.com/q/212010/79) if any one has any experience of
this I'd love to hear from you.
Ian
Ian Turton
Hi Ian
From the docs I see this:
- baseURL the ‘ResourceURL’ available in the WMTS capabilities.
And also found this example:
https://github.com/mapfish/mapfish-print-e2e-test/blob/master/src/main/webapp/data/www/geoext-print-examples/Print-WMTS-Layers-Using-WMTS-Version-1.0.0/index.html#L49
Looks like it's expecting the main URL of the WMTS service. Try this in
your case: https://xxx.xxxx.co.uk/services/xxxxxxx/wmts
Jose García
Ian
Ian Turton
GeoNetwork-users mailing list
GeoNetwork OpenSource is maintained at http://sourceforge.net/
projects/geonetwork
*Vriendelijke groeten / Kind regards,Jose García
<http://www.geocat.net/>Veenderweg 136721 WD BennekomThe NetherlandsT: +31
(0)318 416664 <+31318416664> <https://www.facebook.com/geocatbv>
<https://twitter.com/geocat_bv>
<https://plus.google.com/u/1/+GeocatNetbv/posts>Please consider the
environment before printing this email.*
On 27 September 2016 at 06:59, Jose Garcia <jose.garcia@anonymised.com> wrote:
Hi Ian
For a REST based WMTS this URL contains the {style} etc elements that
should be substituted before use as a URL/URI which is what MapFish seems
to be objecting to.
And also found this example: https://github.com/mapfish/mapfish-print-e2e-
That example is using KVP (which sadly my service doesn't support) so that
would be correct for that example.
Ian
