[GeoNetwork-users] Work flow in the GeoNetwork interface [SEC=UNCLASSIFIED]
Hi All,
First of all I don't want to criticise GeoNetwork. I think it is the best CSW around at the moment and it's wonderful work that the developers have done so far. However, ...
What I find extremely frustrating with GeoNetwork interfaces is that it is so hard to see a map of the data. Users want see a map image more than seeing the metadata or downloading the resource but there doesn't seem to be a button to select in the metadata search results page that will add that map to the existing map.
The flow should be search for something, look at the WMS image on the existing map and then download it if the user wants that data. Hence "see metadata", "show map" and "download resource" should be the three major things of equal importance available on the search results page. Of course many resources don't have WMS images but those that do are not that easy to display.
Having nice things like publish to twitter, face book and rate this metadata record is OK but the most important things that a user wants are:
1. what's available (search)
2. what does it look like (show the map)
3. look at metadata and
4. download the data.
In most cases looking at the metadata is the last or second but last thing that a user wants to do when the user wants to find out more about the data yet it is mostly the only thing that one can do with GN interfaces.
Are there any GeoNetwork interfaces where I can do a search and then immediately "show the map"? I'd like to demonstrate this to some toffs to show that GN is a really good tool for users and not just a presentation of developers skills.
Thanks in advance for any useful GN interfaces.
John Hockaday
Spatial Standards Group (OSDM)
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
http://www.osdm.gov.au/
john.hockaday\@osdm.gov.au
hi John,
What about the button "interactive map" ? (see screenshot here
http://tinypic.com/view.php?pic=6qyud3&s=7). When clicked, it adds the map
to the existing map. Or is this not what you are talking about?
Kind rehards
Heikki Doeleman
On Mon, Jul 4, 2011 at 2:24 AM, <john.hockaday@anonymised.com> wrote:
Hi All,
display.
developers skills.
John Hockaday
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
All of the data generated in your IT infrastructure is seriously valuable.
Why? It contains a definitive record of application performance, security
threats, fraudulent activity, and more. Splunk takes this data and makes
sense of it. IT sense. And common sense.
http://p.sf.net/sfu/splunk-d2d-c2
GeoNetwork-devel mailing list
Hi John
To show the Interactive map button in the search results, your metadata
requires the online resources properly filled (see this:
http://geonetwork-opensource.org/manuals/2.6.4/users/quickstartguide/new_metadata/index.html#linking-wms-online-resources
Also for the data to download you can check in the manual how to manage (
http://geonetwork-opensource.org/manuals/2.6.4/users/quickstartguide/new_metadata/index.html#linking-data-for-download
Jose García
On Mon, Jul 4, 2011 at 1:12 PM, heikki <tropicano@anonymised.com> wrote:
hi John,
Kind rehards
Heikki Doeleman
Hi All,
display.
developers skills.
John Hockaday
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
hi john,
we use an alternate approach. we store the service metadata in a special
postgres database and search directly in the database. the information model
is not the one which is defined by ogc csw 2.0.2 ap iso 1.0.
we allow searching after single wms layers, wfs featuretypes which are
configured before (a simple wfs client definition is done by the service
providers) and after wmc documents. these docs can be published by the
different providers.
i think, that the standard based approach - implementing a client for the csw
interface - is not the right way. there are many informations which are not
part of the iso19115 or iso19119. (quality/validity of services, licences,
authorization, ...).
a central sdi portal have to handle all this information. the iso metadata is
only a part of it.
we use geonetwork as a broker and cause it has a csw interface which is
demanded for the european sdi (inspire). for this purposes it is a very good
software (many apis and conform to many standards).
we push the service-/dataset metadata from our 'service registry' into
geonetwork. this metadata is conforment to the iso standards and in many cases
the needed service-/data metadata coupling is given.
to make use of the concept behind csw 2.0.2 ap iso 1.0 the clients have to
harvest all metadata and resolve the linkages between services (layer) an the
corresponding data-metadata. the biggest problem is that all the records have
to be consistent :frowning: .
i think, that it will only be possible to handle this thru a harvesting of
service-metadata like geonetwork implements it. the system create a metadata
record for every laytaer which has a MetadaUrl entry.
maybe you can try to search for maps in our portal:
http://www.geoportal.rlp.de/portal/en/service/search.html?cat=dienste&searchfilter=searchText%3D*%26resultTarget%3Dfile%26outputFormat%3Djson%26languageCode%3Den
note: i dont think, that all this a problem of the geonetwork software. it is
a problem of the used standards :wink:
regard
armin
Am Montag 04 Juli 2011, 03:24:07 schrieb john.hockaday@anonymised.com:
Hi All,
to display.
John Hockaday
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
--- All of the data generated in your IT infrastructure is seriously
valuable. Why? It contains a definitive record of application performance,
security threats, fraudulent activity, and more. Splunk takes this data
and makes sense of it. IT sense. And common sense.
GeoNetwork-users mailing list
Im Auftrag
Armin Retterath
Zentrale Stelle Geodateninfrastruktur
LVermGeo RP
Ferdinand-Sauerbruch-Straße 15
56073 Koblenz
Telefon 0261/492-466
Telefax 0261/492-492
armin.retterath@anonymised.com
Hi All,
First of all thanks very much for your prompt replies.
Secondly, I apologise for not remembering the "Interactive Map" and "Download" buttons. Apparently the metadata on our site that I thought had both of these hasn't any more so I couldn't see them in our interface.
Also, we are using the 'guiwidgets' interface and it was even harder for me not to see the icons for map and download. I think I will look into changing those into more obvious buttons. ;--)
Finally, I'm very impressed with the responses. I have seen some very nice interfaces and I thank you all for sending them to me. I also feel, that although I was wrong in my first post, that the thread has provided some nice discussion so I am happy with the results even if it was to my embarrassment. ;--)
I think that a users workshop like the developers hack fest may help GeoNetwork break into the non-GIS users area.
Thanks.
John
-----Original Message-----
Sent: Monday, 4 July 2011 11:24 AM
To: geonetwork-users@lists.sourceforge.net;
geonetwork-devel@lists.sourceforge.net
Subject: [GeoNetwork-devel] Work flow in the GeoNetwork
Hi All,
the existing map.
John Hockaday
GPO Box 378
Canberra ACT 2601
(02) 6249 9735
seriously valuable.
data and makes
I think you make some good points John. And I don't think that anything you
list here would be major hurdles to implement. Most the pieces are already
in the interface, but how the are emphasized and used makes a big
difference. GIS is a visual discipline. When we work we tend to first look
at the data then the textual descriptions. There is a huge desire amongst us
to "see it for ourselves". I think your summation is good -
So to discover "whats available (search)" we tend to like good visuals. A
good enhancement to the visual approach to searching is the inclusion of
wireframes of the metadata search results in an enlarged "Where?" map. This
is relatively easy to implement. The improvement I would like is to then
make these wireframes interactive - allowing refining the search by
selecting wireframes.
I personally think the thumbnail approach is the best way to present the
answer to "what does it look like". Creating thumbnails (large and small)
that provide the most informative visual representation of a data set often
takes a good deal of design skill and cannot be automated. But doing this
can often provide more informative visuals than presenting the the data
whole. In the search results display I like to emphasize the thumbnail. One
improvement I would like to implement is to have the large thumbnail appear
on a mouse-over event and then perhaps bring up the wms or other mapservice,
if present, when clicked.
As for "looking at the metadata", in practice, one of the first thing I want
to know generally, is "where did it come from" or "who made it". In all the
shops that I have been in this is the first question asked regarding the
quality of the data. (We should already know "where is it" from the enhanced
search, but this could also be emphasized by highlighting the wireframe
extents on the "Where?" map.) I also want to know the Title, a bit of the
abstract, and maybe keywords at first glance. The rest of the metadata I
would only want to see if I felt that the data were a good match to my
needs. Then access this information in a drill down fashion.
"Downloading the data", while it sounds straight forward, in practice, often
isn't. For instance, if the metadata repository is being used primarily to
manage internal resources, this may need to provide an internal link to the
location of the source data, the folder or database in which it resides. If
it is serving data to a broader external audience then download links from a
repository or maybe a map service might be appropriate. Every shop is
different. Perhaps a good approach is to remove these different options from
the main search results page and place them in a single configurable "Get
Data" button.
These are just a few of my thoughts and experiences to throw into the
conversation. I think this is a good conversation to have because from my
experience, issues of workflow and presentation have been some of the
biggest barriers to implementing GeoNetwork, or any other metadata system
for that matter.
Byron
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Work-flow-in-the-GeoNetwork-interface-SEC-UNCLASSIFIED-tp6544582p6547493.html
Sent from the GeoNetwork developer mailing list archive at Nabble.com.
