[GeoNetwork-users] Working Import XSL for ArcGIS Metadata XML?
Hello all,
does anybody has a working import for metadata created by proprietary GIS
software that is quite popular in germany named ArcGIS?
Of course I tried the options ArcCatalog8_to_ISO19139.xml and
ARCGIS2FGDC.xml - but the results does not convince me. Any click to view
metadata result in the error "Too many nested template or function calls.
The stylesheet may be looping." - by the way: The error is not displayed
properly, see here:
[IMG]http://i.imgur.com/3olp3.jpg\[/IMG\]
ArcGIS also has an export for ISO19139 that does not work with german
language pack, even if I uninstall this package floats have decimal commas
and not dots, so import also fails.
As ArcGIS is quite popular, I assume there is a way for easy importing - who
can help with this issue?
TIA,
-moenk
Geomatics Lab | Geography Department | Humboldt-Universitaet zu Berlin
web: http://www.hu-geomatics.de
View this message in context: http://osgeo-org.1560.n6.nabble.com/Working-Import-XSL-for-ArcGIS-Metadata-XML-tp4681475p4681475.html
Hi Moenk,
Is your problem occurring when you try to display the metadata? I have the impression from your screenshot that the import itself didn't generate errors!? Did yo inspect the resulting XML record?
Jeroen
On 3 apr. 2012, at 11:39, moenk wrote:
Hello all,
properly, see here:
[IMG]Imgur: The magic of the Internet
TIA,
-moenk
Better than sec? Nothing is better than sec when it comes to
monitoring Big Data applications. Try Boundary one-second
resolution app monitoring today. Free.
http://p.sf.net/sfu/Boundary-dev2dev
GeoNetwork-users mailing list
Jeroen,
import works and the editor could be used afterwards. The error message does
not appear any more when I edit and close/save the form (but this has to be
done on each record).
Anyway fields does not look fine, the results are not acceptable and start
like this:
[QUOTE]
Date 20050507
Time 223445
Process CopyFeatures "Database Connections\Connection to
gdi.geo.hu-berlin.de.sde\GEO.BERLIN.ATKIS\GEO.BERLIN.F1
08_P" \\PC-K-118-04\gdi\atkis\F108_P.shp # 0 0 0
ToolSource C:\Program Files
(x86)\ArcGIS\Desktop10.0\ArcToolbox\Toolboxes\Data Management
Tools.tbx\CopyFeatures
Date 20120329
Time 163404
itemName F108_P
Sync TRUE
imsContentType 002
Sync TRUE
itemSize 0,000
Sync TRUE
linkage file://\\PC-K-118-04\gdi\atkis\F108_P.shp
Sync TRUE
protocol Local Area Network
Sync TRUE
type Projected
Sync TRUE
[/QUOTE]
I guess there's a way to import ArcCatalog Metadata as this software is
quite popular and see the result properly formatted, not all this
uninteresting crap, there is also binary encoded data that I think to have
been the thumbnail.
For my further investigation I'd like to know whats the proposed way to
import ArcCatalog Metadata and if there's someone who did it.
-moenk
web: http://www.geographie.hu-berlin.de
View this message in context: http://osgeo-org.1560.n6.nabble.com/Working-Import-XSL-for-ArcGIS-Metadata-XML-tp4681475p4681833.html
