Hi List,
I have a GeoNetwork instance running that reports version 2.6.4. When I issue this xml.metadata.category request I receive an error (see request and response below). I am logged in and other requests (such as CSW Insert) work correctly. Is it possible that the metadata category services are not available in version 2.6.4? I couldn't find a change log anywhere to consult.
Thanks in advance for your assistance.
Dave Lowther
Coordinate Solutions, Inc
Request to http://[server]/geonetwork/srv/en/xml.metadata.category
<request>
<id>24ce1885-1c53-49e0-89d3-466a0ae10523</id>
<_17 />
</request>
Response:
<error id="service-not-found">
<message>Service not found</message>
<class>ServiceNotFoundEx</class>
<stack>
<at class="jeeves.server.dispatchers.ServiceManager" file="ServiceManager.java" line="365" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java" line="670" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="185" method="execute" />
<at class="jeeves.server.sources.http.JeevesServlet" file="JeevesServlet.java" line="108" method="doPost" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="641" method="service" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java" line="722" method="service" />
<at class="org.apache.catalina.core.ApplicationFilterChain" file="ApplicationFilterChain.java" line="305" method="internalDoFilter" />
<at class="org.apache.catalina.core.ApplicationFilterChain" file="ApplicationFilterChain.java" line="210" method="doFilter" />
<at class="org.apache.catalina.core.StandardWrapperValve" file="StandardWrapperValve.java" line="225" method="invoke" />
<at class="org.apache.catalina.core.StandardContextValve" file="StandardContextValve.java" line="169" method="invoke" />
</stack>
<object>xml.metadata.category</object>
<request>
<language>en</language>
<service>xml.metadata.category</service>
</request>
</error>
