That would explain it.
Thanks a lot for your help.
Josh
-----Original Message-----
From: Kumaran Narayanaswamy [mailto:kumaran.narayanaswamy@anonymised.com]
Sent: Friday, 5 August 2011 1:07 PM
To: Vote, Josh (CESRE, Kensington); geonetwork-users@lists.sourceforge.net
Subject: RE: [GeoNetwork-users] xml.metadata.get missing geonet:info in latest Geonetwork
Hello Josh,
By default the geonet:info is not returned in xml.metatdat.get. It is
controlled through settings in config.xml located under WEB-INF
<service name="xml.metadata.get">
<class name=".services.metadata.Show">
<param name="skipPopularity" value="y" />
<param name="skipInfo" value="y" />
</class>
</service>
Change the skipInfo value from Y to n and then you will receive the
geonet:info in xml.metadata.get service
Regards
Kumaran
From: Josh.Vote@anonymised.com [mailto:Josh.Vote@anonymised.com]
Sent: Friday, August 05, 2011 7:12 AM
To: geonetwork-users@lists.sourceforge.net
Subject: [GeoNetwork-users] xml.metadata.get missing geonet:info in latest
Geonetwork
I've noticed recently that responses from 'xml.metadata.get' are missing the
additional 'geonet:info' element that is documented at
http://geonetwork-opensource.org/latest/developers/xml_services/metadata_xml
_services.html#get-metadata-xml-metadata-get
Ie if I were to make a request to
http://my.fake.hostname/geonetwork/srv/en/xml.metadata.get?uuid=XXXXX
I would get a <gmd:MD_Metadata> element but no <geonet:info> element. Is the
development team aware of this issue?
I can confirm that it is this behaviour is occurring under
* Geonetwork trunk (build from last week sometime)
* Geonetwork 2.6.3
And can also confirm that this was last working under version (there may
have been more recent working instances but I haven't tested them).
* Geonetwork 2.4
Thanks
Josh Vote
BlackBerry® DevCon Americas, Oct. 18-20, San Francisco, CA The
must-attend event for mobile developers. Connect with experts.
Get tools for creating Super Apps. See the latest technologies.
Sessions, hands-on labs, demos & much more. Register early & save!
http://p.sf.net/sfu/rim-blackberry-1
GeoNetwork-users mailing list
