If I try to import metadata through "XML Metadata Insert" on the
following file, geonetwork reacts with an error message: "Root element
not set"
<Metadata xmlns="http://www.opengis.net/gml"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
</Metadata>
If I remove the namespace attributes the import works.
Any idea what causes this behaviour?
Willem Nieuwenhuis
nieuwenhuis@anonymised.com
Hi Willem,
did you select the right schema? If you are trying to add a 19139 metadata
you have to provide the full iso 19139 structure. Example:
<DS_DataSet xmlns="http://www.isotc211.org/2005/gmd"
xmlns:gts="http://www.isotc211.org/2005/gts"
xmlns:gco="http://www.isotc211.org/2005/gco"
xmlns:gml="http://www.opengis.net/gml"
<has>
<MD_Metadata>
</MD_Metadata>
</has>
</DS_DataSet>
not set"
</Metadata>
Willem Nieuwenhuis
