Hi Francois,
The reason for using metadata.update is that the metadata record may already exist. If it doesn't then I use metadata.insert.
The metadata that I am using could have 3000 updates a day. If I used metadata.delete and then a metadata.insert, I may run out of unique ID's in a few years. Metadata.update keeps the same ID.
The issue with using batch import is that I would have to separate all the metadata into categories and do multiple batches. Batch import only allows one category to be selected.
By using XML services I can also metadata.admin to set the allowed operations, i.e. set a public view on insert. Therefore I can automate almost all aspects of the metadata management.
Would moving to Tomcat help?
Jamie
-----Original Message-----
From: Francois Prunayre [mailto:fx.prunayre@anonymised.com]
Sent: December 22, 2010 05:35
To: Rupert, James
Cc: geonetwork-users@lists.sourceforge.net
Subject: Re: [GeoNetwork-users] XML metadata services
Hi Jamie,
2010/12/21 Rupert, James <James.Rupert@anonymised.com>:
I am trying to use the xml metadata services to load / update over 10,000 metadata records with version 2.6.1 on Jetty.
It works really well for the first 75 records (< 3 seconds per update) then slows down for the next 75 and then crawls for the next 25 until I get a Out of Memory Error: Java heap space.
Does anyone have an idea for a fix?
Looks strange, I have been using xml.user.login+metadata.insert without any trouble from JMeter to load thousand of records and without changing default jetty memory parameter:
http://www.neogeo-online.net/blog/archives/428/
Why are you using metadata.update instead of metadata.insert ?
For the out of memory error, you could increase the Xmx parameter in startup script.
Cheers.
Francois
Methods used:
xml.user.login
xml.search
Then either
metadata.insert
Or
metadata.update (yes this can be used, but I loop through version
numbers until the correct one is found, resets to 1 after a server
restart) Then
xml.user.logout
Any help would be appreciated.
Also, validation does not seem to work with the XML services, but the records validate with a batch import.
Jamie
James Rupert
Natural Resources Canada | Ressources naturelles Canada Earth
Sciences Sector | Secteur des sciences de la Terre Mapping and
Information Branch / Direction de l'information et de la cartographie
Data Management Division / Division de la gestion des données
601 Booth Street | 601 Rue Booth
Ottawa, Ontario
K1A 0E8
Telephone | Téléphone 613-992-6433
Facsimile | Télécopieur 613-944-6749
Government of Canada | Gouvernement du Canada
-------- Forrester recently released a report on the Return on
Investment (ROI) of Google Apps. They found a 300% ROI, 38%-56% cost
savings, and break-even within 7 months. Over 3 million businesses
have gone Google with Google Apps:
an online email calendar, and document program that's accessible from
your browser. Read the Forrester report:
http://p.sf.net/sfu/googleapps-sfnew
GeoNetwork-users mailing list
