Hello list,
If I type in my browser :
http://172.57.57.57:8080/geonetwork/srv/en/xml.search? I get a list of 11
results, with elements <createDate>2010-10-15T16:23:03</createDate> and
<changeDate>2010-10-15T16:23:03</changeDate>, among others.
If I type
http://172.57.57.57:8080/geonetwork/srv/en/xml.search?dateFrom=2010-10-15T01:00:00&dateTo=2010-10-16T01:00:00
or whatever date range that should include results, I get :
<response from="0" to="0" selected="0">
<summary count="0" type="local" hitsusedforsummary="0">
<keywords/>
</summary>
</response>
Same results if I try with only dates and no times :
http://172.57.57.57:8080/geonetwork/srv/en/xml.search?dateFrom=2010-10-15&dateTo=2010-10-16
Any idea what I'm doing wrong ?
It's GeoNetwork 2.6.0
Alain
View this message in context: http://osgeo-org.1803224.n2.nabble.com/xml-search-with-dateFrom-and-dateTo-tp5681524p5681524.html
The same problem applies if I use the advanced search on GeoNetwork's web
interface. With "anytime", it finds all results, with any date range, no
results at all.
I inspected lucene's index with luke and noticed the _changeDate field is
present and filled in with the expected values.
Any idea ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/xml-search-with-dateFrom-and-dateTo-tp5681524p5686091.html
interface.
http://172.57.57.57:8080/geonetwork/srv/en/main.search.embedded?dateFrom=2009-10-01&dateTo=2010-10-31
: no results
http://172.57.57.57:8080/geonetwork/srv/en/main.search.embedded : all
results available
Any idea ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/xml-search-with-dateFrom-and-dateTo-tp5681524p5686121.html
Hi
I tested with 2.6.0 version and branch 2.6.X code and seem working ok for
me. When using the gui the dates include time information:
dateFrom 2010-10-28T00:00:00
dateTo 2010-10-30T00:00:00
Not sure why you get the dates without time in the gui service, but this can
be the problem, to get no results.
Also similar results for me using xml.search service.
Maybe someone can try also to check.
Jose García
interface.
: no results
results available
Any idea ?
Nokia and AT&T present the 2010 Calling All Innovators-North America
contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in
marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
GeoNetwork-users mailing list
Thanks for your reply.
I removed the times to make the request more clear, along with the other
search parameters.
I tried with times to exclude this possibility :
http://172.57.57.57:8080/geonetwork/srv/en/main.search.embedded?dateFrom=2009-10-01T00:00:00&dateTo=2010-10-31T00:00:00
: no results
results
I didn't change anything to the code of the app, so I don't understand why
it doesn't work here but well when you try it.
Write permissions needed on some folder ? Is some temporary file written
somewhere ?
Alain
View this message in context: http://osgeo-org.1803224.n2.nabble.com/xml-search-with-dateFrom-and-dateTo-tp5681524p5686434.html
Hi
No file permissions required as I know.
I tried with the sample metadata, but no extensive tests performed. Did some
date range queries, checking the change date in the results returned to
check that was correct.
If in log4j.cfg file you set search to DEBUG, you should get in
geonetwork.log the lucene query that is using GeoNetwork, so you can try
with Luke to verify if any result. Maybe also post here to verify with my
query.
Jose García
search parameters.
: no results
results
somewhere ?
Alain
contest
marketing
I have to leave work now, but I'll try this on wednesday. Next step is
finding luke's query syntax.
Thanks for the hint
View this message in context: http://osgeo-org.1803224.n2.nabble.com/xml-search-with-dateFrom-and-dateTo-tp5681524p5686670.html
Hello,
I found out that the lucene query wasn't the <request> ... </request> but
the small line at the end.
In my logs, I read :
+(_op0:1) +_isTemplate:n +changeDate:[2005-11-01T07:24:00.000Z TO
2010-11-30T07:24:00.000Z]
This query in Luke returns indeed 0 results. If I add an underscore before
changeDate, it seems to work OK in Luke :
+(_op0:1) +_isTemplate:n +_changeDate:[2005-11-01T07:24:00.000Z TO
Would it be OK if I add an underscore in
/geonetwork/trunk/web/src/main/java/org/fao/geonet/kernel/search/LuceneIndexField.java
at the line
public static final String CHANGE_DATE = "changeDate";
or would it rather screw it up ?
Alain
The reason why I'm encountering this and not you is maybe because I'm using
Tomcat 7 ?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/xml-search-with-dateFrom-and-dateTo-tp5681524p5700409.html
