Hi
There's a service for this: metadata.admin.form (see the definition in
WEB-INF/config-metadata.xml), but it outputs html. The service accepts the
metadata uuid as a parameter.
If you want only the xml response, you can add new service definition in
WEB-INF/config-metadata.xml, like this:
<service name="metadata.privileges">
<class name=".services.metadata.GetAdminOper"/>
</service>
If using 2.10 you also need to add in
WEB-INF/config-security-mapping.xmlthis like
<sec:intercept-url pattern="/srv/.*/metadata. privileges!?.*"
access="hasRole('Administrator')"></sec:intercept-url>
After these changes GeoNetwork requires a restart.
If no option to add a new service, you can call the existing one in debug
mode (adding ! to the URL). Not optimal, but should do the work:
http://localhost:8080/geonetwork/srv/eng/metadata.admin.form*!*
?uuid=METADATA_UUID
This invocation returns the complete xml that is passed to the xslt that
creates the html.
In the xpath /root/groups you can access to the privileges information of
each group (privileges set in oper nodes with <on /> element):
<group userGroup="true">
<id>3</id>
<name>Group1</name>
<description>
</description>
<email/>
<referrer/>
<label>
<eng>Group1</eng>
</label>
<oper>
<id>0</id>
*<on/>*
</oper>
<oper>
<id>1</id>
</oper>
Jose García
On Wed, Nov 27, 2013 at 9:25 AM, udhaya <udhay.forum@anonymised.com> wrote:
Hello,
I would like to know if there is any XML services in geonetwork Where I
can fetch the Privilege for a Given metadata . For example I want know
which
all groups has view only access for this metadata and which all group has
edit and other access for this metadata.
Please let me know. Thanks
View this message in context:
http://osgeo-org.1560.x6.nabble.com/XML-Services-to-Fetch-Meatdata-Privilege-tp5091409.html
Rapidly troubleshoot problems before they affect your business. Most IT
organizations don't have a clear picture of how application performance
affects their revenue. With AppDynamics, you get 100% visibility into your
Java,.NET, & PHP application. Start your 15-day FREE TRIAL of AppDynamics
Pro!
http://pubads.g.doubleclick.net/gampad/clk?id=84349351&iu=/4140/ostg.clktrk
GeoNetwork-users mailing list
* GeoCat Bridge for ArcGIS allows instant publishing of data and metadata
on GeoServer and GeoNetwork. Visit http://geocat.net
<http://geocat.net/> for details. _________________________Jose
GarcíaGeoCat bvVeenderweg 13 6721 WD BennekomThe
Netherlandshttp://GeoCat.net/> *
