hi everyone,
i am using XML services to update my metadata into geonetwork-2.10 using a
java program which in turn uses XML sevices as given in developers manual.
But when i am trying to do login then http 500 error is coming.
help is requested.
Thanks in advance
Hi Nitesh
In 2.10 version, GeoNetwork started to use Spring Security, so the services
xml.user.login and xml.user.logout are not longer available.
You can use Basic Authentication in your requests for the authentication.
Jose GarcĂa
On Wed, Feb 4, 2015 at 12:13 PM, Nitesh Kaushik <kaushik.nitesh@anonymised.com>
wrote:
hi everyone,
help is requested.
Thanks in advance
Dive into the World of Parallel Programming. The Go Parallel Website,
sponsored by Intel and developed in partnership with Slashdot Media, is
your
hub for all things parallel software development, from weekly thought
leadership blogs to news, videos, case studies, tutorials and more. Take a
look and join the conversation now. http://goparallel.sourceforge.net/
GeoNetwork-users mailing list
*GeoCat Bridge for ArcGIS allows instant publishing of data and metadata on
GeoServer and GeoNetwork. Visit http://geocat.net/> for
details. _________________________Jose GarcĂaGeoCat bvVeenderweg 136721 WD
BennekomThe Netherlandshttp://GeoCat.net/>*
