[GeoNetwork-users] XML validation error when adding a dataset to the metadata record
Hi
Hope you can help. I am getting an XML error when I try to attach data to my
metadata record.
The record validates until I try to add the dataset.
• I open ‘Distribution information’
• Then ‘Distribution format’ where I add the name and version
• Then ‘transfer options’
• ‘Online resource’
• Choose file for download in ‘protocol’.
• I upload a file
• It says it uploads successfully; It puts a URL in the ‘URL’ section. The
URL looks right.
I save and then check and I get this error in the validation report.
Compliance to metadata standard (XML Schema) (1 errors)
    Invalid element. Invalid content was found starting with element:
(gmx:MimeFileType). One of the following elements Text (gco:CharacterString)
is expected.Parent element is Name (gmd:name)
Attached is the error path and the XML.
<http://osgeo-org.1560.n6.nabble.com/file/n5009493/error_path.png&gt;
<http://osgeo-org.1560.n6.nabble.com/file/n5009493/xml.png&gt;
Any help with this will be really appreciated.
Cheers, Tim
View this message in context: http://osgeo-org.1560.n6.nabble.com/XML-validation-error-when-adding-a-dataset-to-the-metadata-record-tp5009493.html
Hi Tim,
I have come across the same issue i.e validation complaining about a gmx:MimeFileType
underneath a parent gmd:name when its expecting a gco:CharacterString.
Could be to do with the way you are running the validation, are you running
validation inside:
- GN's editor or
- are running validation through some other software such as ANZMETlite
- or an XML editor such as XML Spy?
I find this issue when I used the validator in XML Spy and I set the schemaLocation as
xsi:schemaLocation="http://www.isotc211.org/2005/gmd/gmd.xsd&quot;
then I see an error like yours:
Element <gmx:MimeFileType> is not allowed under element <gmd:name>.
Reason: The following elements are expected at this location (see below)
  <gco:CharacterString>
  <gmd:DS_InitiativeTypeCode>
  <gmd:MD_CharacterSetCode>
   Error location: gmd:MD_Metadata / gmd:distributionInfo / gmd:MD_Distribution / gmd:transferOptions / gmd:MD_DigitalTransferOptions / gmd:onLine / gmd:CI_OnlineResource / gmd:name / gmx:MimeFileType
Details
  cvc-model-group: Element <gmx:MimeFileType> unexpected by type 'gco:CharacterString_PropertyType' of element <gmd:name>.
  cvc-elt.5.2.1: The element <gmd:name> is not valid with respect to the actual type definition 'gco:CharacterString_PropertyType'.
If however you reference the schema location to the local ISO19139 schema.xsd on your system (not web) like this:
xsi:schemaLocation="http://www.isotc211.org/2005/gmd file:///C:/ANZMEST_SVN9279/web/geonetwork/WEB-INF/data/config/schema_plugins/iso19139/schema.xsd">
the validation will be fine.
So your XML is most likely OK it's just saying its invalid because
of the way the schema xsd is referenced. Just to check I did the same as you
uploading a local file for download using the recent GN V2.8.0RC1 test version.
The XML validates OK using the validator in GN editor i.e the 'Check' button.
HTH
Andrew
----- Original Message ----- From: "timdavies" <tdavies@anonymised.com>
To: <geonetwork-users@lists.sourceforge.net>
Sent: Thursday, October 18, 2012 2:27 PM
Subject: [GeoNetwork-users] XML validation error when adding a dataset tothe metadata record
HiHope you can help. I am getting an XML error when I try to attach data to mymetadata record.The record validates until I try to add the dataset.• I open ‘Distribution information’• Then ‘Distribution format’ where I add the name and version• Then ‘transfer options’ • ‘Online resource’• Choose file for download in ‘protocol’.• I upload a file• It says it uploads successfully; It puts a URL in the ‘URL’ section. TheURL looks right.
  Invalid element. Invalid content was found starting with element:(gmx:MimeFileType). One of the following elements Text (gco:CharacterString)is expected.Parent element is Name (gmd:name)
Attached is the error path and the XML.<http://osgeo-org.1560.n6.nabble.com/file/n5009493/error_path.png&gt; <http://osgeo-org.1560.n6.nabble.com/file/n5009493/xml.png&gt;
Any help with this will be really appreciated.Cheers, Tim
--View this message in context: http://osgeo-org.1560.n6.nabble.com/XML-validation-error-when-adding-a-dataset-to-the-metadata-record-tp5009493.htmlSent from the GeoNetwork users mailing list archive at Nabble.com.
------------------------------------------------------------------------------Everyone hates slow websites. So do we.Make your web apps faster with AppDynamicsDownload AppDynamics Lite for free today:http://p.sf.net/sfu/appdyn_sfd2d_oct_______________________________________________GeoNetwork-users mailing listGeoNetwork-users@anonymised.com://lists.sourceforge.net/lists/listinfo/geonetwork-usersGeoNetwork OpenSource is maintained at http://sourceforge.net/projects/geonetwork
Hi Andrew,
Thanks for the advice. I'll try changing where the schema is referenced and
let you know how it goes.
For your reference, I created the record in GN and ran the validation in GN.
I am also using GN version 2.7.0-SNAPSHOT
Cheers, Tim
View this message in context: http://osgeo-org.1560.n6.nabble.com/XML-validation-error-when-adding-a-dataset-to-the-metadata-record-tp5009493p5009744.html
