I have created my XML using the iso19139 schema.xsd
The errors below are popping up when I try to import my metadata record into
GeoNetwork, if anyone has any ideas it would be very much appreciate.
METADATA IS NOT VALID.
XSD Validation error(s)
cvc-complex-type.2.4.a: Invalid content was found starting with element
'gmd:dateStamp'. One of '{"http://www.isotc211.org/2005/gmd":hierarchyLevel,
"http://www.isotc211.org/2005/gmd":hierarchyLevelName,
"http://www.isotc211.org/2005/gmd":contact\}' is expected. (Element:
gmd:dateStamp with parent element: gmd:MD_Metadata)
'gmd:identifier'. One of
'{"http://www.isotc211.org/2005/gmd":alternateTitle,
"http://www.isotc211.org/2005/gmd":date\}' is expected. (Element:
gmd:identifier with parent element: gmd:CI_Citation)
cvc-enumeration-valid: Value '' is not facet-valid with respect to
enumeration '[farming, biota, boundaries, climatologyMeteorologyAtmosphere,
economy, elevation, environment, geoscientificInformation, health,
imageryBaseMapsEarthCover, intelligenceMilitary, inlandWaters, location,
oceans, planningCadastre, society, structure, transportation,
utilitiesCommunication]'. It must be a value from the enumeration. (Element:
gmd:MD_TopicCategoryCode with parent element: gmd:topicCategory)
cvc-type.3.1.3: The value '' of element 'gmd:MD_TopicCategoryCode' is not
valid. (Element: gmd:MD_TopicCategoryCode with parent element:
gmd:topicCategory)
View this message in context: http://osgeo-org.1560.n6.nabble.com/XSD-Validation-Errors-tp5035852.html
