geoserver-2.26-SNAPSHOT-gwc-azure-blobstore-plugin doent work anymore in the 2.26.x series
We have been using this module for years, now it doesnt work anymore.
In the admin console, when creating a new blobstore, the azure blobstore option soes not appear.
Trying to load a configuration with azure blobstores (that works in 2.25.4) geoserver crashes.
Is this a known issue? Will womething be done about it?
That is a community module so there is no real expectation that someone will fix it for you. If you depend on this module then you’ll either need to fix it yourself or pay someone to fix it for you.
Ian
info for anyone who is blocked by this issue:
2.26.1 works with the 2.25.x module.
Needs testing of course
It is not a known issue, your feedback helps bring it to everyone’s attention.
As you are the first person to notice, do you have any idea what is not working? Anything warning in the logs etc…
Can you compare the jars included in the download with the previous version - maybe something important was left out? Sometimes when updating jars not everything is included in the download zip correctly.
Yep, it happened for example when upgrading the S3 libraries and an external contributor diagnosed the issue and provided a patch, it was indeed some missing library:
This could be the same, the Azure libraries have received a major upgrade in the last few months.
