[Geoserver-devel] 1.2.3 bugs
So I have a list of posible issues:
startup: the second option works, but
[dzwiers@anonymised.com geoserver]$ ./bin/startup.sh
: bad interpreter: No such file or directory
[dzwiers@anonymised.com geoserver]$ java -jar bin/start.jar
it cannot find xalan:
<ServiceExceptionReport version="1.2.0"
xsi:schemaLocation="http://www.opengis.net/ogc
http://localhost:8080/geoserver/data/capabilities//wfs/1.0.0/OGC-exception.xsd&quot;&gt;
  <ServiceException>
      javax.xml.transform.TransformerFactoryConfigurationError: Provider
org.apache.xalan.processor.TransformerFactoryImpl could not be
instantiated: java.lang.NullPointerException
</ServiceException>
</ServiceExceptionReport>
Anyone have any ideas?
David
Wht is your java -version ?
Perhaps you are running an old version of Java that does not include xerces? Xalan would really like to talk to xerces ...
Jody
<ServiceException>
instantiated: java.lang.NullPointerException </ServiceException>
David
This SF.net email is sponsored by: IT Product Guide on ITManagersJournal
Use IT products in your business? Tell us what you think of them. Give us
Your Opinions, Get Free ThinkGeek Gift Certificates! Click to find out more
http://productguide.itmanagersjournal.com/guidepromo.tmpl
Geoserver-devel mailing list
Does 'sh startup.sh' work? What shell are you using? And what
permissions does the file have? Can you chmod it to be executeable if
it's not, and then does it work?
For the second, it's because you're on java 1.5. This is mentioned
somewhere in the docs, basically you just have to copy the xalan.jar to
the lib directory . server/geoserver/WEB-INF/lib in the binary release.
I'm still not convinced on including xalan, as it's a big jar, but as java
1.5 gets more accepted (and if sun doesn't start including it), then I'm
sure we probably will.
Chris
  <ServiceException>
</ServiceException>
David
Using bash, and i unziped the new version parallel to 1.2.2 (which runs
fine).
ls -l has 755 for the startup.sh
Ok i'll try ... xalan is on my classpath.
Chris
> <ServiceException>
> </ServiceException>
> David
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
fine).
-rwxr-xr-x 1 dzwiers users 2435 Oct 13 22:36 startup.sh
same state as before ...
This part is fixed, it runs now :slight_smile:
> Chris
David
> > <ServiceException>
> > </ServiceException>
> > David
> > _______________________________________________
