[Geoserver-devel] 1.3.0a, a couple gotchas on FeatureType Editor with Oracle Spatial
Tooltips on the wrong thing for FeatureTypeEditor:
- Min Long - tooltip is: Minimum Lat value for FeatureType
- Max Long - tooltip is: Maximim Lat value for FeatureType
- Min Lat: - tooltip is: Minimum Long value for FeatureType
- Max Lat: - tooltip is: Maximum Long value for FeatureType
Does anyone have any suggestions for asking GeoServer to display data with out a SRS? A CAD projection would be fine.
I admit such a thing may not be possible give the structure of WMS getCapabilities.
I was also unable to change basic mappings from the UI anymore? Am I to understand that changing the Schema Base to a string will pick up a schema file in the data directory?
Motivation: I was wanting to help GeoServer figure out that SDO_GEOMETRY actually was a Geometry - it showed up as blank?
Jody
