[Geoserver-devel] 1.4.0-M0 Hit List
We are getting close to our first 1.4.x release. Here is a list of things that still need to be done.
1. Running Cite Tests
2. Testing Build Docs against Writing Guidelines
3. Release Guide
4. Programmers Guide
So if anyone is bored and feel like helping out please let me know.
-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Justin Deoliveira wrote:
- requires an editor (who has an confluence account)
- best done by a new developer who does not know maven yet
3. Release Guide
I am not bored but would like to write down what you want to see for the Programmers Guide above, I have looked at the GEOSDOC site and would like to know where to put which doc, and have a list of what remains to be written.
Chris? I expect that some of the "Experimental" work is best moved over to the GeoDEV site, and not listed in any "guide" at all, aka when these experiments are ready to merge back in they can prep pages for inclusion in the documentation. Is this your understanding?
Jody
Hi Justin,
Well I a have time on my hands how can I help?
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM MSN : louiecw@anonymised.com
IM Skype: louicw
3. Release Guide
-Justin
Cool, thanks Clint!
Why dont you start on the release docs. Update your 1.4.x source tree and document the process of using maven to build the release here:
http://docs.codehaus.org/display/GEOSDEV/2+Development
If you have any questions please feel free to ask.
-Justin
Clint Lewis wrote:
Hi Justin,
Justin Deoliveira
I ran firstly
mvn clean install assembly:assembly
and secondly
mvn clean install assembly:assembly -DMaven.test.skip=true
but I get this error on both accounts..
[INFO] [compiler:testCompile]
Compiling 22 source files to C:\projects\geoserver\1.4.x\test\target\test-classes
[INFO] [surefire:test]
[INFO] Setting reports dir: C:\projects\geoserver\1.4.x\test\target/surefire-reports
T E S T S
java.lang.ExceptionInInitializerError
        at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
        at java.lang.reflect.Method.invoke(Unknown Source)
        at org.apache.maven.surefire.battery.JUnitBattery.processTestClass(JUnitBattery.ja
va:130)
        at org.apache.maven.surefire.battery.JUnitBattery.<init>(JUnitBattery.java:81)
        at org.apache.maven.surefire.SurefireUtils.instantiateBattery(SurefireUtils.java:6
3)
        at org.apache.maven.surefire.Surefire.instantiateBatteries(Surefire.java:262)
        at org.apache.maven.surefire.Surefire.run(Surefire.java:140)
        at org.apache.maven.surefire.Surefire.run(Surefire.java:87)
        at org.apache.maven.surefire.Surefire.run(Surefire.java:63)
RUN ABORTED
        at org.apache.maven.surefire.SurefireBooter.main(SurefireBooter.java:785)
Caused by: java.lang.NullPointerException
        at org.vfny.geoserver.requests.RequestTestCase.<clinit>(RequestTestCase.java:44)
        ... 16 more
org.apache.maven.surefire.Runner
An exception or error caused a run to abort.
null
Cool, thanks Clint!
-Justin
Clint Lewis wrote:
Hi Justin,
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
I will figure out what is happening with the Test, what it is failing..
Clint Lewis wrote:
I ran firstly
and secondly
T E S T S
va:130)
3)
RUN ABORTED
       ... 16 more
null
Cool, thanks Clint!
-Justin
Clint Lewis wrote:
Hi Justin,
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
Nice catch Clint!
I think I fixed this so if you could update and try again that would be great. Also the property to skip tests is spelled wrong in your example its all lower case (-Dmaven.test.skip=true).
-Justin
Clint Lewis wrote:
I ran firstly
and secondly
T E S T S
va:130)
3)
RUN ABORTED
       ... 16 more
null
Cool, thanks Clint!
-Justin
Clint Lewis wrote:
Hi Justin,
Justin Deoliveira
Nice catch Clint!
I figured this one out now.. thanks anyway
-Justin
Clint Lewis wrote:
I ran firstly
and secondly
T E S T S
va:130)
3)
RUN ABORTED
       ... 16 more
null
Cool, thanks Clint!
-Justin
Clint Lewis wrote:
Hi Justin,
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
Nice catch Clint!
You sure you commited it.. I get nothing on my side
-Justin
Clint Lewis wrote:
I ran firstly
and secondly
T E S T S
va:130)
3)
RUN ABORTED
       ... 16 more
null
Cool, thanks Clint!
-Justin
Clint Lewis wrote:
Hi Justin,
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
It is now :slight_smile:
Nice catch Clint!
-Justin
Clint Lewis wrote:
I ran firstly
and secondly
T E S T S
va:130)
3)
RUN ABORTED
       ... 16 more
null
Cool, thanks Clint!
-Justin
Clint Lewis wrote:
Hi Justin,
Justin Deoliveira
Hi Justin,
Another error I received
INFO: about to create map ctx for BasicPolygons with bounds Env[-2.0 : 2.0, -1.0 : 6.0]
java.io.FileNotFoundException: \tmp\testSimpleGetMapQuery.gif (The system cannot find the
path specified)
        at java.io.FileOutputStream.open(Native Method)
        at java.io.FileOutputStream.<init>(Unknown Source)
        at org.vfny.geoserver.wms.responses.map.GIFMapProducerTest.assertNotBlank(GIFMapPr
oducerTest.java:54)
        at org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest.testSimpleGetMapQ
uery(DefaultRasterMapProducerTest.java:118)
        at junit.framework.TestCase.runTest(TestCase.java:154)
        at junit.framework.TestCase.runBare(TestCase.java:127)
        at junit.framework.TestCase.run(TestCase.java:118)
        at junit.framework.TestSuite.runTest(TestSuite.java:208)
        at junit.framework.TestSuite.run(TestSuite.java:203)
        at org.apache.maven.surefire.battery.JUnitBattery.executeJUnit(JUnitBattery.java:2
42)
        at org.apache.maven.surefire.battery.JUnitBattery.execute(JUnitBattery.java:216)
        at org.apache.maven.surefire.Surefire.executeBattery(Surefire.java:215)
        at org.apache.maven.surefire.Surefire.run(Surefire.java:163)
java.io.FileNotFoundException: \tmp\testDefaultStyle BasicPolygons.gif (The system cannot
find the path specified)
oducerTest.java:54)
        at org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest.testDefaultStyle(
DefaultRasterMapProducerTest.java:253)
DefaultRasterMapProducerTest.java:134)
42)
java.io.FileNotFoundException: \tmp\testBlueLake.gif (The system cannot find the path spec
ified)
oducerTest.java:54)
        at org.vfny.geoserver.wms.responses.DefaultRasterMapProducerTest.testBlueLake(Defa
ultRasterMapProducerTest.java:190)
42)
[surefire] org.vfny.geoserver.wms.responses.map.GIFMapProducerTest <<<<<<<< FAILURE !!
2006/05/29 01:55:18 org.vfny.geoserver.wms.responses.map.svg.EncodeSVG encode
INFO: SVG generated in 16 ms
[ERROR] BUILD ERROR
[INFO] Total time: 1 minute 37 seconds
[INFO] Finished at: Mon May 29 13:55:18 CAT 2006
[INFO] Final Memory: 14M/30M
Nice catch Clint!
-Justin
Clint Lewis wrote:
I ran firstly
and secondly
T E S T S
va:130)
3)
RUN ABORTED
       ... 16 more
null
Cool, thanks Clint!
-Justin
Clint Lewis wrote:
Hi Justin,
Kind Regards
Clint Lewis
IM Yahoo: louiecwza
IM Skype: louicw
3. Release Guide
Yup, makes sense. Just update the links appropriately when you move the stuff over (if you do the right confluence moves it should be automatic).
All the docs are children and sub-children of: http://docs.codehaus.org/display/GEOSDOC/Experimental
     * Complex Feature Documentation
           o Complex Feature include
     * RelationshipDataStore
     * WCS and Raster Documentation
           o GeoServer WCS Specifications
           o GeoTiff
           o WCS include
Jody
All the advantages of Linux Managed Hosting--Without the Cost and Risk!
Fully trained technicians. The highest number of Red Hat certifications in
the hosting industry. Fanatical Support. Click to learn more
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=107521&bid=248729&dat=121642
Geoserver-devel mailing list
Chris Holmes
http://topp.openplans.org
