maven build configs missing. Has something not been comitted?
error log:
Downloading: http://repository.codehaus.org/org/geoserver/maven/build-configs/1.
4.0/build-configs-1.4.0.jar
[WARNING] Unable to get resource from repository codehaus.org (http://repository
.codehaus.org)
Downloading: http://repo1.maven.org/maven2/org/geoserver/maven/build-configs/1.4
[WARNING] Unable to get resource from repository central (http://repo1.maven.org
/maven2)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.maven:build-configs:jar:1.4.0
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.geoserver.maven -DartifactId=build-
configs \
-Dversion=1.4.0 -Dpackaging=jar -Dfile=/path/to/file
Path to dependency:
1) org.codehaus.mojo:jalopy-maven-plugin:maven-plugin:1.0-20060707.04011
1-3
2) org.geoserver.maven:build-configs:jar:1.4.0
1 required artifact is missing.
for artifact:
org.codehaus.mojo:jalopy-maven-plugin:maven-plugin:1.0-20060707.040111-3
from the specified remote repositories:
codehaus.org (http://repository.codehaus.org),
central (http://repo1.maven.org/maven2),
snapshots (http://snapshots.repository.codehaus.org),
codehaus-snapshot-plugins (http://snapshots.repository.codehaus.org/)
Brent Owens
(The Open Planning Project)
Strange, seems it is trying to download the build-configs plugin. Are you building from the root? All the plugins under the maven directory should be included in the build by default.
-Justin
error log:
.codehaus.org)
/maven2)
[ERROR] BUILD ERROR
Missing:
configs \
Path to dependency:
1-3
for artifact:
Justin Deoliveira
jdeolive@anonymised.com
http://topp.openplans.org
yeh building from the root.
I'm going to clear the repository and try again, maybe there is something weird going on in there.
Brent Owens
-Justin
error log:
.codehaus.org)
/maven2)
[ERROR] BUILD ERROR
Missing:
configs \
Path to dependency:
1-3
for artifact:
Odd, if it doesn;t work i suggest you comment out the jalopy part of the root pom and try again.
Brent Owens
-Justin
error log:
.codehaus.org)
/maven2)
[ERROR] BUILD ERROR
Missing:
configs \
Path to dependency:
1-3
for artifact:
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier.
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
!DSPAM:1004,45d24ee3242701460912952!
Justin Deoliveira
yeh commenting that out fixed it.
Now onto other errors =)
Brent Owens
Brent Owens
-Justin
error log:
.codehaus.org)
/maven2)
[ERROR] BUILD ERROR
Missing:
configs \
Path to dependency:
1-3
for artifact:
Sorry, it's something I fixed on 1.5.x but not on 1.4.x
build-configs is in the build, but it's not the first item.
No other modules depend on it as a real jar dependency, but
web uses it for configuration. It should be enough
to do the same I did on 1.5.x, make it the first item in
the root pom submodules list.
