Hi Efren,
I assume you mean different versions? Not currently but this is definitley a goal for the short term as WFS 1.1 starts to come around. Actually doing so will be fairly straight forward.
-Justin
Efren Serra wrote:
Folks,
Is it possible to hook-up several Geoserver WFS? Thank you.
v/r,
Efren-----Original Message-----
[mailto:geoserver-devel-admin@lists.sourceforge.net]On Behalf Of Justin
Deoliveira
Sent: Thursday, May 18, 2006 8:37 AM
To: Geoserver-devel
Subject: [Geoserver-devel] 1.4.x and WFSHi all,
After a few days of playing with Spring, Clint and I have got the WFS
module behaving just like before, except for now it is a true "plug-in".
Clint is working madly documenting the module system.One of the nice side effects of breaking things out into modules and
wiring them together with spring is the dependencies between system
components are actually documented in the spring context files. Which
means you can get a high level picture of the GeoServer architecture
without having to wade through code.Its a pity I cant commit since codehaus is down. Someone really dropped
the ball on that one. I mean a week is pretty unreasonable for an open
source project to be without version control. Once I can commit I look
forward to running cite tests against 1.4.x.-Justin
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com-------------------------------------------------------
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job
easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Justin Deoliveira
