Hi folks,
I'm trying to fix the maven2 build of Geoserver 1.4.x branch
and having a few problems.
First, the ki libraries weren't published on any repo -> I did published
them on lists.refractions.net for the sake of building.
Then, batik is available on ibiblio, but version 1.5 and 1.6. We are apparently
using 1.5.1. Any reason for not updating to 1.6?
Someone lately published a pdf map producer on 1.4.x without updating the
pom.xml files. That's ok, I fixed it, but had to reference itext 1.3 since
1.4 is still not published onto the ibiblio repositories.
Which version are we supposed to use?
Andrea Aime
Andrea Aime wrote:
Hi folks,
You can get rid of them, and the whole zserver package that uses them. There may be one other place in the code that references zserver that isn't in the package, but I think it may be gone already. The code is no longer used no longer used.
Not that I know of.
1.3.6 is the one it was built against, so 1.3 I imagine should be fine.
Chris
Andrea Aime
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
Chris Holmes
The Open Planning Project
http://topp.openplans.org
