[Geoserver-devel] 1.4.x WCS
hey
i have downloaded gt_trunk and 1.4.x wcs merge. then i built the
geoserver.war. till this point everything went ok. but now when i try to
deploy geoserver.war in Tomcat (any version) Tomcat says it can't deploy
application. what could be wrong?
this is the Tomcat output
INFO: Deploying web application archive geoserver.war
28.7.2006 14:00:33 org.apache.catalina.startup.HostConfig deployWAR
SEVERE: Error deploying web application archive geoserver.war
java.lang.IllegalArgumentException:
log4j,openmap,postgis,jts,junitperf,junit,postgresql-Extension-Name
  at java.util.jar.Attributes$Name.<init>(Unknown Source)
  at java.util.jar.Attributes.getValue(Unknown Source)
  at
org.apache.catalina.util.ManifestResource.getRequiredExtensions(ManifestResource.java:185)
  at
org.apache.catalina.util.ManifestResource.processManifest(ManifestResource.java:154)
  at
org.apache.catalina.util.ManifestResource.<init>(ManifestResource.java:51)
  at
org.apache.catalina.util.ExtensionValidator.validateApplication(ExtensionValidator.java:185)
  at
org.apache.catalina.core.StandardContext.start(StandardContext.java:4035)
  at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:759)
  at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:739)
  at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:524)
  at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:809)
  at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:698)
  at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:472)
  at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1122)
  at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:310)
  at
org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(LifecycleSupport.java:119)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1021)
  at org.apache.catalina.core.StandardHost.start(StandardHost.java:718)
  at org.apache.catalina.core.ContainerBase.start(ContainerBase.java:1013)
  at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:442)
  at org.apache.catalina.core.StandardService.start(StandardService.java:450)
  at org.apache.catalina.core.StandardServer.start(StandardServer.java:709)
  at org.apache.catalina.startup.Catalina.start(Catalina.java:551)
  at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
  at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Unknown Source)
  at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:294)
  at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:432)
View this message in context: http://www.nabble.com/1.4.x-WCS-tf2015051.html#a5538328
Sent from the GeoServer - Dev forum at Nabble.com.
Remove the wkb4j.jar from /webapps/geoserver/lib directory … actually it does not allow Tomcat to deploy GeoServer war due to a problem in the METAINFO.MF descriptor.
On 7/28/06, GeoUser <blazrepnik@anonymised.com> wrote:
hey
deploy geoserver.war in Tomcat (any version) Tomcat says it can’t deploy
at java.util.jar.Attributes$Name.(Unknown Source)
at
org.apache.catalina.util.ManifestResource.getRequiredExtensions(ManifestResource.java :185)
at
at
org.apache.catalina.util.ManifestResource.(ManifestResource.java:51)
at
org.apache.catalina.util.ExtensionValidator.validateApplication (ExtensionValidator.java:185)
at
at
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java :809)
at org.apache.catalina.startup.HostConfig.start (HostConfig.java:1122)
at
at
at org.apache.catalina.core.ContainerBase.start(ContainerBase.java :1013)
at org.apache.catalina.core.StandardServer.start (StandardServer.java:709)
at sun.reflect.NativeMethodAccessorImpl.invoke (Unknown Source)
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java :294)
Join SourceForge.net’s Techsay panel and you’ll get the chance to share your
opinions on IT & business topics through brief surveys – and earn cash
Geoserver-devel mailing list
Alessio Fabiani
Software Engineer
http://afabiani.wordpress.com
This does beg a question of if we're even using wkb4j any more, as I feel like Blasby might have rewritten the binary code or used stuff from JTS. Probably worth looking in to. Though he might have just done it for PostGIS, and MySQL may need the update.
C
Alessio Fabiani wrote:
Remove the wkb4j.jar from <tomcat>/webapps/geoserver/lib directory ... actually it does not allow Tomcat to deploy GeoServer war due to a problem in the METAINFO.MF descriptor.
On 7/28/06, *GeoUser* <blazrepnik@anonymised.com <mailto:blazrepnik@anonymised.com>> wrote:
    hey
    try to
           at
    :185)
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
           at
    Source)
    :294)
    Sent from the GeoServer - Dev forum at Nabble.com <http://Nabble.com>.
    Join SourceForge.net's Techsay panel and you'll get the chance to
    share your
    opinions on IT & business topics through brief surveys -- and earn cash
    <http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV&gt;
    <mailto:Geoserver-devel@lists.sourceforge.net>
Alessio Fabiani
Software Engineer
--------------------------------------------------------- !DSPAM:1003,44ca043b128716309890654!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
thanks a lot !! it works now
View this message in context: http://www.nabble.com/1.4.x-WCS-tf2015051.html#a5543694
