Hi Alessio/1.5 developers
I'm trying to build 1.5 and got this test error. Any ideas what it is and how to resolve it?
[ERROR] BUILD FAILURE
[INFO] Trace
org.apache.maven.BuildFailureException: There are test failures.
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(Defa
ultLifecycleExecutor.java:555)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLi
fecycle(DefaultLifecycleExecutor.java:475)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(Defau
ltLifecycleExecutor.java:454)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHan
dleFailures(DefaultLifecycleExecutor.java:306)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegmen
ts(DefaultLifecycleExecutor.java:273)
at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLi
fecycleExecutor.java:140)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:322)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:115)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:256)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.plugin.MojoFailureException: There are test failures
at org.apache.maven.plugin.surefire.SurefirePlugin.execute(SurefirePlugi
n.java:403)
at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPlugi
nManager.java:412)
ultLifecycleExecutor.java:534)
... 16 more
[INFO] Total time: 2 minutes 18 seconds
[INFO] Finished at: Tue Nov 14 08:36:36 PST 2006
[INFO] Final Memory: 22M/49M
Brent Owens
(The Open Planning Project)
I also notice that the cruise control build has been down for a while,
since Nov 6th.
-Justin
[INFO]
[INFO]
[INFO]
[INFO] Trace
at
at
at
at
at
at
at
java:39)
at
sorImpl.java:25)
at
at
failures
at
n.java:403)
at
nManager.java:412)
at
... 16 more
[INFO]
[INFO]
Justin Deoliveira
jdeolive@anonymised.com
http://topp.openplans.org
since Nov 6th.
I've just built trunk with jdk 1.4.2_12 and it works just fine?
I have no local changes.
hmm
ok I'm going to blow everything away and reinstall and try again. Anything else I have tried so far hasn't worked. It may be related to a build issue I have in 1.4 too.
Brent Owens
since Nov 6th.
