1.5.x fails to build (mnv install, after svn update and mvn clean),
apparently some local windows rubbish made it into subversion... See
last line of mvn output below.
Compiling 1 source file
to /usr/local/src/geoserver/branch_1.5.x/geoserver/web/target/test-classes
[INFO] [surefire:test] [INFO] Surefire report
directory: /usr/local/src/geoserver/branch_1.5.x/geoserver/web/target/surefire-reports
[INFO] [jar:jar] [INFO] Building
jar: /usr/local/src/geoserver/branch_1.5.x/geoserver/web/target/web-1.5.0-RC1.jar
[INFO] [config:config {execution: configPackage}]
config:
[INFO]
[ERROR] BUILD ERROR [INFO]
[INFO] Failed to execute: Executing Ant script: /config.build.xml
[config]: Failed to execute.
Unable to locate configuration:
D:\Java\Geoserver\gs1.5\configuration/release
config:
[INFO]
Release? Sorry, what build parameter did you use?
To get something like this I have to run mvn install with parameters:
mvn install -DconfigDirectory=../../configuration -DconfigId=release
but in my case it wo.... no, it does not... ah, I see, there's an
error in the web module POM... fixed, should work now
On Tue, 13 Feb 2007 12:33:49 +0100
> config:
> [INFO]
Cheers for fixing
I never use some release parameter, should I? I usually just do mvn
install, and then deploy the war file on my tomcat server, where I have
defined a data_dir so all the config etc. remains fine. Hmm, now that I
think of it, would the minimal release make my war file smaller? That
would shorten the downtime while redeploying the app in tomcat, because
the uploading takes a significant amount of time. Of course, I could
upload by hand first and then deploy from the server, too...
Cheers for fixing
Sorry, I did not notice that the config id parameter was changed as well. The default was minimal already, I fixed this too.
