[Geoserver-devel] 1.6.5 Install
All,
Well done on the .exe installation / configuration. I’ve recently ran the 1.6.5 windows exe installer and was quite impresssed with how easy this was to setup and test. My only comment would be the installer didn’t setup the data_dir I defined correctly (there were some closed bugs in Jira relating to older versions so this may just have been defered).
David
Hi David,
Thanks! Good to hear GeoServer is working out for you! Updating our windows installer is definitely something on the list of things to do. Hopefully an update to it will solve these sorts of issues.
-Justin
David Zwiers wrote:
All,
Well done on the .exe installation / configuration. I've recently ran the 1.6.5 windows exe installer and was quite impresssed with how easy this was to setup and test. My only comment would be the installer didn't setup the data_dir I defined correctly (there were some closed bugs in Jira relating to older versions so this may just have been defered).
David
This SF.Net email is sponsored by the Moblin Your Move Developer's challenge
Build the coolest Linux based applications with Moblin SDK & win great prizes
Grand prize is a trip for two to an Open Source event anywhere in the world
http://moblin-contest.org/redirect.php?banner_id=100&url=/
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
