[Geoserver-devel] 1.6 beta2 with Mod_JK?
I'm trying to stand up a version of geoserver 1.6 beta2 on our servers
at work. Now for historical reasons they are configured differently
(this is good for beta testing I guess). On one machine all is fine.
Linux webmapping.ems.psu.edu 2.6.9-55.0.2.EL #1 Tue Jun 12 17:47:10
EDT 2007 i686 i686 i386 GNU/Linux
tomcat 5.5.20 running to port 80 using proxy pass in Apache2 2.2.3
Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_10-b03)
On the other machine all seems fine until I try to log in as admin
Linux slant.geog.psu.edu 2.6.9-55.0.2.ELsmp #1 SMP Tue Jun 12 17:59:08
tomcat 5.0.28 running to port 80 using mod_jk in apache 2.0.52
When I try to login in to the second machine I get 404 The requested
URL /geoserver-1.6b2/j_acegi_security_check was not found on this
server.
I'm guessing this has to do with using Mod_JK but I'm not an expert
with this? and I just copied and pasted the setup from geoserver 1.5
and changed 1.5 to 1.6 through out. Does any one have an suggestions?
Ian
Ian Turton
http://www.geotools.org
http://pennspace.blogspot.com/
Hmmm... unfortunately most users go straight though tomcat or another app server and not through apache so knowledge of problems with mod_jk is limited... if i get some spare time today i will try to set it up and see what i come up with...
Ian
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
server.
Hmm... some years ago I tried to use mod_jk but it was such a can
of worms I gave up :slight_smile:
Anyways, a quick Google search turns out these:
http://forum.springframework.org/showthread.php?t=10334
http://forum.springframework.org/archive/index.php/t-34918.html
Are these of any help?
> server.
This one worked
thanks
Ian
